April 19th, 2018, 9:35
st2000dm001 9yn164-500 cc4b
I wanted to back up my data. I plugged the power. and this occurs.
I used to identical PCB. Everything is the same except the serial number.( swapping chip already). but it is useless.
Now i lost the flash chip.
- Attachments
April 19th, 2018, 9:44
If you lost ( don´t know where it is ) the flash chip, then game over. No cheap solution.
If you still have the flash chip, why do you believe it is damaged ? Try reading it in an external programmer.
April 19th, 2018, 11:43
I think he's referring to this IC, which is not the BIOS.
- ST2000DM001 burnt IC.jpg (32.68 KiB) Viewed 9462 times
April 19th, 2018, 11:54
i know that is not flash chip..
but it needs donor PCB.
identical PCB can't solve problem.
at the end i lost the flash chip at my home.
after all I'm afraid to change seagate PCB.
7200.14 series is a troublemaker.
April 19th, 2018, 12:00
I understand he doesn´t have the chip anymore. If that is so, then no use to keep insisting with this hard disk. He can store it in some place in the case he founds the chip on the floor later.
April 19th, 2018, 13:56
Spildit wrote:Most likely it's NOT his drive and it's a client HDD instead if we take intro consideration the number of posts done by the OP on the last day(s) regarding diferent drives ...
Sad ...
Very sad indeed, for the poor customers
I bet they won’t find out WHY they haven’t got their data back, they’ll be told some pack of lies no doubt
April 19th, 2018, 14:31
pcimage wrote:Spildit wrote:Most likely it's NOT his drive and it's a client HDD instead if we take intro consideration the number of posts done by the OP on the last day(s) regarding diferent drives ...
Sad ...
Yeah!... clients must f...d by only DR company.
These are my disks. i bought that from wrecker because i need donor drive, at least PCB .
when i recover a disk i got a many oppurtunity.. you know..
Recovered data needs another hdd.
i never harm clients data.. Most of successfully recovered. as you can see below.
https://forum.donanimhaber.com/memberRe ... emID=94826
mikail13 on April 19th, 2018, 14:41, edited 1 time in total.
April 19th, 2018, 14:52
Clients sends to me only patient disk.
i send recovered data with another healhty disk.
mass of data needs another hard drive.
it can be shipping another city.
April 19th, 2018, 15:10
mikail13 wrote:Clients sends to me only patient disk.
- Attachments
- Capture.JPG (41.27 KiB) Viewed 9414 times
