 Post subject: Diablo 3S unknown problem
PostPosted: May 15th, 2018, 9:30
HDD: [b]WD20PURX-64P6ZY0
Rom: 15.0BC
Problem: Not Detected
Tool : WDMarvel 3.3.1[/b]
1. When connected the hdd goes bsy bsy forever
2. When SA region edit then shows firmware version and model
When try to load Overlay 11 then error
"Error loading module ID11 into RAM, state - 0101"
3. After SA Edit and restore it then can read all modules without problem by ID
but can't write anything (since 11 is not loaded)
IF I try to read sector by sector then "VSCE_UNSUP_ACTION_CODE"
IF I try to load mod 11 then "Error loading module ID11 into RAM, state - 0101"
here attached Rom and loader
ROM.rar [215.75 KiB]
Downloaded 334 times
Loader.rar [485.89 KiB]
Downloaded 323 times
How to proceed..?
 Post subject: Re: Diablo 3S unknown problem
PostPosted: May 15th, 2018, 10:10
What tool are you using? PC-3000, MRT?
Edit: Disregard that question... I missed the fact that you already said you're using WDMarvel. I'm afraid I've got no experience working with that tool, so I probably can't help much.
It might be worth trying a different module 11. Sometimes one will work where another failed.
PostPosted: May 16th, 2018, 3:00
Tried with someother loaders but failed.
the attached mod 11 is read from this drive
PostPosted: May 16th, 2018, 4:05
Problem Solved
Data Recovered
Users browsing this forum: Google [Bot], mima85 and 40 guests
