 Post subject: ST1000DM003 suddenly disappeared from BIOS
PostPosted: May 7th, 2018, 19:04
Starts fine, no strange tick/click noises so i think it is "fine", i got TTL UART converter and read some data from it. Takes too long to receive any reply from it.
I tried by connecting in USB to SATA adapter and i noticed that it keeps displaying (H) SATA reset, (S) SATA reset, (P) SATA reset while using the USB to SATA adapter, but it is taking like forever for any reply. By the USB adapter i was able to see the device and partitions on windows, but it took more than 15 minutes and the system got frozen after that. Is it too bad damaged?
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
ASCII Diag mode
F3 T>
(P) SATA Reset
F3 T>N5
Invalid Diag Cmd
F3 T>
Current R/W User LBA 000000000000 LLL CHS 000000.0.0000 PLP CHS 000000.0.0000
R/W Status 1 R/W Error 00000080 Ready - PCC 170e UT 21055.403280
F3 T>
R/W Status 1 R/W Error 00000080 Ready - PCC 170e UT 21055.404540
F3 T>/1
F3 1>N1
Clear SMART is completed.
F3 1>N5
Att
Num  Flgs normlzd worst raw
1   000F   64     FD   00000000000000
3   0003   64     FD   00000000000000
4   0032   64     FD   00000000000000
5   0033   64     FD   00000000000000
7   000F   64     FD   00000000000000
9   0032   64     FD   00000000000000
A   0013   64     FD   00000000000000
C   0032   64     FD   00000000000000
B7   0032   64     FD   00000000000000
B8   0032   64     FD   00000000000000
BB   0032   64     FD   00000000000000
BC   0032   64     FD   00000000000000
BD   003A   64     FD   00000000000000
BE   0022   64     FD   00000000000000
BF   0032   64     FD   00000000000000
C0   0032   64     FD   00000000000001
C1   0032   64     FD   00000000000000
C2   0022   28     28   00002800000000
C5   0012   64     FD   00000000000000
C6   0010   64     FD   00000000000000
C7   003E   C8     FD   00000000000000
F0   0000   64     FD   00000000000000
F1   0000   64     FD   00000000000000
F2   0000   64     FD   00000000000000
0   0000    0      0   00000000000000
F3 1>
Spinning Down
Spin Down Complete
Elapsed Time 10.565 secs
Delaying 5000 msec
Jumping to Power On Reset▒
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
ASCII Diag mode
F3 T>/1
F3 1>N5
Att
7   000F   64     FD   00000000000004
BE   0022   64     FD   00000080800000
C0   0032   64     FD   00000000000002
C1   0032   64     FD   00000000000001
F3 1>
 Post subject: Re: ST1000DM003 suddenly disappeared from BIOS
PostPosted: May 7th, 2018, 19:21
Yeah, it is bad.
If you don´t need the data, buy another ( from other brand ) .
If you need the data, why were you cleaning smart ?
PostPosted: May 7th, 2018, 19:25
rogfanther wrote:
Yeah, it is bad.
Mistype, when i noticed N1 in place of N5 i almost cried :/
Do you think still possible recover data?
PostPosted: May 7th, 2018, 19:28
Probably yes, but if the data is important it would be better to send it to a professional.
This drives are of low quality, and not amenable to too much tinkering. Messing too much with it can make recovery much more expensive, if not impossible.
PostPosted: May 7th, 2018, 19:33
Do you have any hint? Maybe replacing PCB would help? Maybe there is problem with the heads? I found a perfect donor for parts for this hdd on eBay, ordering this drive and sending together to the repair center would help them to read the contents of the disk?
PostPosted: May 7th, 2018, 20:44
1. replacing the PCB will not help
2. if you send it to a reputable DR pro/company they don't need your help to find parts "if needed"
3. it "MIGHT" be still in a stage (needs further testing) where it can be recovered without parts, so it will be a waste of money if dont need it
PostPosted: May 7th, 2018, 20:49
3. it "MIGHT" be stiil in a stage (needs further testing) where it can be recovered without parts, so it will be a waste of money if dont need it
Hear the man!
And just to add to (2), if the company needs you to find a donor disk for them, then they are not reputable enough and you should go to other place.
Of course, we are talking about data recovery companies, not pc repair shops.
Also, in which city you are located ?
PostPosted: May 7th, 2018, 20:56
Joinville - SC
PostPosted: May 11th, 2018, 9:51
Perfect, i'll follow rogfanther's tip and send it to a professional that have PC-3000 tool.
Thank you so much, i'll update this topic with the end of this history.
PostPosted: June 4th, 2018, 20:09
Just got some spare time to pick-up the hdd with the pro. Not 100% of the data has been rescued however the result is great! That was not too expensive also. Thank you @rogfanther, the guy you recommended me is a great DR Pro.
PostPosted: June 4th, 2018, 20:26
Nice !
Glad he could solve it for you!
Users browsing this forum: mima85 and 40 guests
