 Post subject: Seagate Thin SSHD - Not spinning up
PostPosted: June 4th, 2018, 21:30
Good day,
I've received this HDD from one of our clients
Model: ST500LM000
FW: SM30
PCB NO.: 100731589
I have tried swapped ROM to a donor PCB, without avail
Please advise
Best regards
 Post subject: Re: Seagate Thin SSHD - Not spinning up
PostPosted: June 4th, 2018, 22:01
Need log terminal.
PostPosted: June 5th, 2018, 2:50
When did you change PCB then disk start spinning?
Very popular problem with this disk is damaged nand. Then symptoms is like disk is completely dead without any noise and don't spin.
PostPosted: June 5th, 2018, 3:16
Hi lasek,
No, it doesn't spin up even we have swapped to donor PCB
PostPosted: June 5th, 2018, 6:57
Really useless to swap ROM chip on an SSHD drive. If you need data - take it to some skilled engineer
PostPosted: June 6th, 2018, 11:27
Agreed with Masterclass. It's best if you do not mess with it yourself if you are not sure what you are doing.
Yevgeniy. No, NOT Malkin.
Ambassador at ADRSĀ®
Users browsing this forum: Google [Bot] and 54 guests
