 Post subject: Can MHDD Run on Multiple drives at one system ?
PostPosted: June 17th, 2018, 0:56
I am using MHDD for hard disk but running on only one Drive at one system.
There is any option in MHDD that scan, erase on multi drive at a time.
Is MHDD availble in Windows version ??
Please give any suggestion
One more thing is that How to write pattern in HDD/SSD using command.
Divakar
 Post subject: Re: Can MHDD Run on Multiple drives at one system ?
PostPosted: June 17th, 2018, 11:08
Due to its nature and the way it needs to access the disk to work, MHDD works in dos only.
You can try to do whatever you need to do in linux, with more disks connected.
Users browsing this forum: Google [Bot] and 56 guests
