 Post subject: ST1000DM010
PostPosted: July 26th, 2018, 9:46
Hello
Drive in topic came to me with heads stucked to platters, after releasing the heads the drive is spinning normally with full calibration but stuck in busy.
Terminal output:
Boot 0x20M
SpinUp
RECOV Servo Op=0100 Resp=0005
Trans
Rst 0x20M Thermistor Temp 0021
Retry delay
Retry delay
DOS:0 Scan Unit
LD:
PP:
No HOST FIS-ReadyStatusFlags 0002A181
2Sync:01 0C
ASCII Diag mode
F3 T>
Thanks in advance
 Post subject: Re: ST1000DM010
PostPosted: July 27th, 2018, 1:04
Take it to someone skilled if you need data
PostPosted: July 27th, 2018, 8:02
Agree.
Are you skilled enough to do the job and retrieve the data from that drive?
PostPosted: July 29th, 2018, 22:08
there is patch function in MRT to solve No host problem, you can have a try.
Users browsing this forum: No registered users and 63 guests
