 Post subject: Every 20s Clicks Seagate ST32000542AS 2Tb Barracuda LP CC37
PostPosted: August 17th, 2018, 2:31
So, i have HDD Seagate ST32000542AS 2Tb Barracuda LP CC37
- it works, did yesterday MHDD surface test all OK
- reads/writes data ok
Issue:
- if drive idle [ no read/write data] every 20s [ i timed] does single click,
and on repeat. When i do some read/write it stops, and when idle
it starts again.
Tested:
- not OS related, since clicks even in bios menu whilel idle
Question:
- it has fw: CC37, will update to CC35 help ? or
- what can i try ?
Note:
- not about DATA question, don't suggest Backup
Thanks.
 Post subject: Re: Every 20s Clicks Seagate ST32000542AS 2Tb Barracuda LP C
PostPosted: August 17th, 2018, 3:07
Show us the SMART report. In particular, check the load/unload cycle count.
Otherwise, the drive may be performing a background media scan.
PostPosted: August 17th, 2018, 3:18
Fresh stats from AIDA64
ID Attribute Description Threshold Value Worst Data Status
01 Raw Read Error Rate 6 117 100 159352695 OK: Value is normal
03 Spinup Time 0 100 100 0 OK: Always passes
04 Start/Stop Count 20 100 100 9 OK: Value is normal
05 Reallocated Sector Count 36 100 100 0 OK: Value is normal
07 Seek Error Rate 30 63 60 2098252 OK: Value is normal
09 Power-On Time Count 0 100 100 30 OK: Always passes
0A Spinup Retry Count 97 100 100 0 OK: Value is normal
0C Power Cycle Count 20 100 100 9 OK: Value is normal
B7 <vendor-specific> 0 100 100 0 OK: Always passes
B8 End-to-End Error 99 100 100 0 OK: Value is normal
BB Reported Uncorrectable Errors 0 100 100 0 OK: Always passes
BC Command Timeout 0 100 100 0 OK: Always passes
BD High Fly Writes 0 100 100 0 OK: Always passes
BE Airflow Temperature 45 62 59 38 OK: Value is normal
C2 Temperature 0 38 41 38 OK: Always passes
C3 Hardware ECC Recovered 0 49 45 159352695 OK: Always passes
C5 Current Pending Sector Count 0 100 100 0 OK: Always passes
C6 Offline Uncorrectable Sector Count 0 100 100 0 OK: Always passes
C7 Ultra ATA CRC Error Rate 0 200 200 0 OK: Always passes
F0 Head Flying Hours 0 100 253 51 OK: Always passes
F1 Total Host Writes 0 100 253 3524631423 OK: Always passes
F2 Total Host Reads 0 100 253 1676856805 OK: Always passes
Also did search for FW update and notice that the CC37 is newer than CC35,
and downgrading can make worst.
Reminder: - clicks persists when drive just powered, and no OS is booted.
PostPosted: August 17th, 2018, 9:02
Have you checked your PSU? Could also be a power problem...
ACELab partner
PostPosted: August 17th, 2018, 9:06
So i investigated the issue, and it is parking heads noise
in the short idle mode [ 20s in my case] which is set
in the factory by CC37 FW.
So i need to disable APM to fix it.
Will post the progress.
Users browsing this forum: Majestic-12 [Bot] and 44 guests
