 Post subject: Seagate Barracuda 7200.12 unable to backup resources PC-3000
PostPosted: August 26th, 2018, 20:16
Model: ST31000524AS
Detected Family: 3F Pharaoh
Things that work:
    Terminal (get output)
    Boot code and ROM extract via terminal, no need to short pins, auto mode works just fine
    HDD ID and capacity correct
When drive starts it outputs this to terminal
Rst 0x20M
RW: Disc Ctlr Initialization Completed.
(P) SATA Reset
On utility start:
Error initializing microprogram tables! Alternative initialization is possible!
Using HDD resources analysis:
In log: "Tech Key...
Error starting command  "En Tech"  (Drive is not ready)
Using Terminal report:
Terminal : error detecting HDD terminal baud rate
Attempting to read ROM via ATA:
Error : DT ID 15 is not found!
Using Terminal:
    Unable to detect UA or SA Phys Sector Size.
    Drive enters BSY and doesn't leave until power cycle.
    Same with reading DT(RAM) or Modules. Able to read DT(Flash) fine.
Log output:
Detecting UA Phys Sct Size...
Result.................................. : Error
Error obtaining Phys Sect Size!
Using ATA indirect works for Phys Sector Siza SA, UA and DT(Flash) but not DT(RAM)
Data Extractor "Wait.. HDD Initilization" and never exits BSY.
Using HDD resources backup, HDD enters BSY after "Reading autotuning buffer"
On some tasks, terminal spits out:
InitiateMarkPendingReallocateRequest for disc_lba: 3AADF723!
(DOS) Read Unrecoverable Error
etc..
Check heads gives me:
Head 00 Resistance 00FA
Head 01 Resistance 00EF
Head 02 Resistance 0117
Head 03 Resistance 015F
What diagnostic steps would you suggest next? I'm unable to open the drive to inspect the platters or heads. I am pretty new to the PC-3000 so don't assume I'm not missing something super obvious. What's going on with this drive?
Thanks in advance to anybody who can help :)
Users browsing this forum: No registered users and 82 guests
