 Post subject: Remove TLER WD Red
PostPosted: September 30th, 2018, 19:27
Is there a way to remove the TLER of the WD Red NAS drives to convert them to a consumer drive ?
drugstoredir2014.com
 Post subject: Re: Remove TLER WD Red
PostPosted: September 30th, 2018, 19:32
http://files.hddguru.com/download/Software/Western%20Digital/WDTLER.zip
PostPosted: October 3rd, 2018, 18:30
Spildit wrote:
In your post it says it can dammage newer drives but there is no cut of date or drive model compatibility mentioned any where I can find.
The drives are wd10efrx drives
PostPosted: October 3rd, 2018, 23:14
You can change the TLER setting from the Error Recovery Control (ERC) menu in HDAT2. However these changes will not survive a power cycle.
User's Manual HDAT2 v4.8:
https://www.hdat2.com/files/hdat2en_48_v10.pdf
You could use WDTLER to retrieve the current values of the TLER timers and compare them against those reported by HDAT2.
Users browsing this forum: Google [Bot] and 102 guests
