 Post subject: ST500LT012-9WS142
PostPosted: October 20th, 2018, 11:50
Hello!
After heads replacement:
CfwDiscCode Not Loaded: 0002A185
Any ideas?
Thanks in advance.
 Post subject: Re: ST500LT012-9WS142
PostPosted: October 20th, 2018, 12:44
Replace heads again and again or finally take hdd to skilled people.
PostPosted: October 20th, 2018, 12:48
Maybe I will, but before that, do you have any idea about the error code?
PostPosted: October 20th, 2018, 15:51
The ROM has a CFW segment (Controller FirmWare). I suspect that "CfwDiscCode" may refer to Controller FirmWare in the SA ??? Maybe you could use a loader?
PostPosted: October 20th, 2018, 16:07
Thanks for reply Mr. Frank, already tried to load ldr but no luck.
I need to know which mod/sysfile to write to fix the error.
I can r/w sysfiles but one by one via hyperteminal.I have a full backup of mdods+ROM and already cloned side 0.
Thanks in advance.
PostPosted: October 20th, 2018, 16:09
IIUC, there are 4 main overlays. I would think that the "CfwDiscCode" would be contained in one of these???
PostPosted: October 20th, 2018, 16:20
I have successfully write both overlay 0,1 in (0x100 and 0x101)
PostPosted: October 21st, 2018, 8:32
Solved. :)
Many thanks to Mr. Frank for shedding the light. :)
