Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD5000AAKS SATA 500G what are these chips?
PostPosted: December 30th, 2007, 11:20
can someone post the type of diode at D3, it seems on my burnt pcb, this is the only component that has been damaged, but i can't seen the type from the pictures posted above.
Thanks.
PostPosted: December 31st, 2007, 2:43
thanks Jono
PostPosted: December 18th, 2008, 14:57
Mikippp wrote:
Yes. New WDC SATA drives AAJS AAKS BEVS... have No Rom.
(Processor is 88i6745 instead of older 88i6545)
88i6545 need external serial Flash.
88i6745 have Flash memory embeded.
If processor is not damaged - it is possible to read ROM in PSV mode (4-jumpers)
Mikippp
Miki,
I'm not familiar with reading ROM from Marvel uC, could you please give detail procedure how to do that ? RS-232 terminal ? Contacts on J2 ?
I have PCB 2060-701-477-001 with 88i6745 chip; HDD is WD5000AAJS-57TKA0.
PostPosted: December 23rd, 2008, 12:13
WD SATA HDD - PSV Mode:
||| - jumpers
Mavr_fl -> Read Flash On WD-Hdd (Marvell CPU)
PS In WD5000AAKS/WD5000AAJS the copy of native ROM is saved in Service Area
Mikippp
PostPosted: December 25th, 2008, 11:47
Which page or module has the copy of the native Rom?
PostPosted: November 12th, 2009, 0:49
1 change MCU chip is hard to do ,
2 to look for same PCB by number on PCB with white lable
3 change motor chip
4 read MCU ROM data into another one
PostPosted: November 12th, 2009, 8:19
99% its SMOOTH chip, or as jono said swapping the MCU is not hard. and it's 99% working because if it is not the drive will not even try to spin.
good luck
PostPosted: November 12th, 2009, 8:37
WD5000AAKS all no external flash/ROM
But did you try read ROM in Kernel mode?
PostPosted: November 16th, 2009, 12:36
Banned User
-----------read rom + modules in kernel mode. -------------
----------get same PCB: 2060-xxxxxx-xxx rev x-----------------
------------write rom + modules to new pcb.------------------
dont worry about model etc. just match PCB: 2060-xxxxxx-xxx rev x
PostPosted: March 25th, 2010, 17:27
If anybody has this firmware downloaded from the drive, can he/she please mail it to me? I'm trying to find out if it is possible to fix a similar problem without the need of an spare PCB/hot swap by directly uploading the firmware to the MCU.
Thanks in advance!
Erik Sollie
Information Technology Peru S.A.C.
www.recuperacion-disco-duro.com
mail: lab.itp@gmail.com
PostPosted: November 16th, 2018, 13:09
I need your help to find the firmware for the same drive, I'm trying to find out if it is possible to fix a similar problem without the need of an spare PCB/hot swap by directly uploading the firmware to the MCU.
[moderator edit: please set up signature in your profile]
Users browsing this forum: Google [Bot] and 43 guests
