 Post subject: Samsung Sp1604n - old IDE - Data recovery
PostPosted: November 17th, 2018, 5:42
Hello guys,
sorry for my english! :D
i got an old Samsung HDD which has a broken PCB. I already bought 3 other kinds of this HDD an switched the boards. It spins up with another PCB but makes a endless clicking sound. I think it it trying to find the right "jump in point" but cannot because the firmware or the bios-chip is not exactly the same.
So i made some measurements and comapred them to the other boards. And just by making these measurements (just ohm, hdd turned off) i broke another PCB.. Oo
And it has the same symptoms now. So now i am stuck and don't know what to do. They diodes should be okay.
My idea now is just to fix the baord of my original HDD. I can't be something to hard to fix. Because i think it just lay around for years after workinmg good. And when i tried to start it again after years, the PCB is broken!? Furthermore you cannot see any damages on the board neither burned stuff or so.
I attach some measurements i made: (red is the original board, and green one of the other before it broke too :D .. both ohm continuity measurements) (yellow was the only "turn on" volt measurement of other boards and red the original)
https://www.dropbox.com/s/c8bxq4kfcou45gf/sasmsungSP1604n.jpg?dl=0
Unfortunately my external HDD connector broke a few minutes ago because i pulled the wires too hard :S. Any advice of a cheap one?
Thanks in advance and cheers!!
