Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: Seagate 2 GB ST2000DM001 Barracuda 7200.14 Recovery Effo
PostPosted: March 24th, 2016, 6:41
3. can you upload sys file 93 ?
what did you mean?
What is T command?
PostPosted: March 24th, 2016, 7:08
Lesiex wrote:
what did you mean?
upload here system file 0x0093 (saved mode pages (HDD ID))
Lesiex wrote:
What is T command?
list of F3 terminal commands.
PostPosted: March 24th, 2016, 7:16
If you don't have expesive tools to do that you can use hyper terminal using a TTL cable
how to read and write sys files using hyper terminal:
https://forum.hddguru.com/viewtopic.php ... 71#p226671
explained by "spildit" in details for newbies here
PostPosted: March 24th, 2016, 7:37
after power cycle i have error on T/
Invalid Diag cmd parameter....
now cant do nothing:/
PostPosted: March 24th, 2016, 7:50
I think DIY time is over, wrap it up and call it a day, and start seeking pro assistance if data is valuable to you.
I really hope that you didn't turned a easy recovery to a hard one
PostPosted: March 24th, 2016, 8:19
ok, its working again - problem witch ttl cont.
in atachments
log from putty
and sys file 93.
i see enetreing commands to disable correction and etc. witchout efect.
after power down and power up correction disable bit still = 0
putty.log [1.41 MiB]
Downloaded 1186 times
FILE_3_093_0.zip [2.63 KiB]
Downloaded 1037 times
PostPosted: March 24th, 2016, 8:26
CTRL + x ?
And please do not attached such a large log (1.4M), just the relevant log
PostPosted: March 24th, 2016, 8:32
sorry,
and this is ctrl+x dump
File comment: ctrl+x
putty2.log [6.06 KiB]
Downloaded 1355 times
PostPosted: March 24th, 2016, 9:46
instead
F"RWRecoveryFlags",00,22
F"RWRecoveryFlags",01,22 (disables read sparing, write sparing and disables correction).
now im testing
PostPosted: March 24th, 2016, 10:05
ok,
now ddrescue speed up to 500-600 kB/s
PostPosted: March 24th, 2016, 11:06
and i try ddrescue -R - no speed gain - still 500-600kB/s
PostPosted: March 25th, 2016, 8:50
Spildit wrote:
Problem with it is that you will get only 1300-1400kb/s
Still better than 500-600KB/s
But I doubt he is gonna get it, I'm thinking degraded/ contaminated heads
PostPosted: March 29th, 2016, 9:41
after jermy help i have avg. speed 4000kB/s but still after some time disk stop be accesable - ddrescue stop revocer , fast count errorzise and finsih.
i must go to termianl /1 N1 -clear smart and can contionue recover.
Anny ideas?
PostPosted: March 29th, 2016, 15:05
when disk hung on terminal i have this output :
F3 T>
(DOS) NEED: 0x00000879BD-0000087AE7 - 0x0005417B-0005417B Count 2120
(DOS)CMP Count 2120
(H) SATA Reset
SSPSaveSettings
SSPRestoreSettings
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
(DOS) NEED: 0x0000087D3E-0000087E68 - 0x0005417E-0005417E Count 2B00
(DOS)CMP Count 2B00
(DOS) File Save
(DOS) NEED: 0x0000087E69-0000087F93 - 0x0005417F-0005417F Count 28C0
(DOS) Refresh Start.
WTR: Outer Timer Expired
(DOS)ABT
(DOS) NEED: 0x0000087F77-0000087F93 - 0x0005417F-0005417F Count 3180
(DOS)CMP Count 3380
(DOS) NEED: 0x00000880BF-00000881E9 - 0x00054181-00054181 Count 33E0
(DOS)ABT
(DOS) NEED: 0x0000088196-00000881E9 - 0x00054181-00054181 Count 4B00
(DOS)CMP Count 4B00
(DOS) NEED: 0x0000087AE8-0000087C12 - 0x0005417C-0005417C Count 2560
(DOS)CMP Count 2560
(DOS) NEED: 0x0000087F94-00000880BE - 0x00054180-00054180 Count 2500
(DOS)CMP Count 2500
(DOS) NEED: 0x00000881EA-0000088314 - 0x00054182-00054182 Count 2380
(DOS)ABT
(DOS) NEED: 0x00000882BF-0000088314 - 0x00054182-00054182 Count 3400
(DOS)CMP Count 3700
(DOS) NEED: 0x0000084179-00000842A3 - 0x00054173-00054173 Count 20F8
(DOS)CMP Count 20F8
(DOS) NEED: 0x0000084750-000008487A - 0x00054178-00054178 Count 2028
(DOS)CMP Count 2028
(DOS) NEED: 0x0000088315-000008843F - 0x00054183-00054183 Count 4780
(DOS)CMP Count 4780
(DOS) NEED: 0x0000088440-000008856A - 0x00054184-00054184 Count 9148
(DOS)ABT
(DOS) NEED: 0x000008852F-000008856A - 0x00054184-00054184 Count A100
(DOS)CMP Count A480
(DOS) NEED: 0x000008856B-0000088695 - 0x00054185-00054185 Count EF80
(DOS)ABT
(DOS) NEED: 0x0000088622-0000088695 - 0x00054185-00054185 Count FE00
(DOS)CMP Count 0580
(DOS) NEED: 0x0000088696-00000887C0 - 0x00054186-00054186 Count C300
(DOS)ABT
(DOS) NEED: 0x000008877F-00000887C0 - 0x00054186-00054186 Count D300
(DOS) Marginal Read: 000008877F
(DOS) Read Error - 43110081
(DOS) Write Failure Reallocation started.
(DOS) AutoWriteReallocationEnabled and Reallocation Request Issued. !00000080
(DOS) WriteFailureReallocateLBARequest is executed successfully.
(DOS) Write Error - 000008877F
(DOS) Marginal Read: 0000088785
(DOS) Write Error - 0000088785
(DOS)ABT
(DOS) NEED: 0x0000088786-00000887C0 - 0x00054186-00054186 Count DB00
(DOS)CMP Count E000
(DOS) NEED: 0x0000087D3E-0000087E68 - 0x0005417E-0005417E Count 26A0
(DOS)CMP Count 26A0
(DOS) NEED: 0x00000880BF-00000881E9 - 0x00054181-00054181 Count 2500
(DOS)CMP Count 2500
(DOS) NEED: 0x00000887C1-00000888EB - 0x00054187-00054187 Count 7200
(DOS) Marginal Read: 0000088827
(DOS)ABT
(DOS) NEED: 0x00000888B1-00000888EB - 0x00054187-00054187 Count 7D00
(DOS)CMP Count 7D00
(DOS) NEED: 0x0000088315-000008843F - 0x00054183-00054183 Count 2280
(DOS)CMP Count 2280
(DOS) NEED: 0x0000088440-000008856A - 0x00054184-00054184 Count 2000
(DOS)ABT
(DOS) NEED: 0x000008852F-000008856A - 0x00054184-00054184 Count 2F80
(DOS)CMP Count 3300
(DOS) NEED: 0x00000836F6-0000083820 - 0x0005416A-0005416A Count 20D8
(DOS)CMP Count 20D8
(DOS) NEED: 0x0000083DF8-000008404D - 0x00054170-00054171 Count 20D8
(DOS)CMP Count 20D8
(DOS) NEED: 0x0000087E69-0000087F93 - 0x0005417F-0005417F Count 23A0
(DOS)CMP Count 23A0
(DOS) NEED: 0x000008856B-0000088695 - 0x00054185-00054185 Count 3300
(DOS)ABT
(DOS) NEED: 0x0000088622-0000088695 - 0x00054185-00054185 Count 4180
(DOS) Marginal Read: 000008867A
(DOS) Write Error - 000008867A
(DOS)ABT
(DOS) NEED: 0x0000088682-0000088695 - 0x00054185-00054185 Count 4C00
(DOS)CMP Count 4C00
(DOS) NEED: 0x00000834A0-00000835CA - 0x00054168-00054168 Count 20B0
(DOS)CMP Count 20B0
(DOS) NEED: 0x0000087C13-0000087D3D - 0x0005417D-0005417D Count 2500
(DOS)ABT
(DOS) NEED: 0x0000087C91-0000087D3D - 0x0005417D-0005417D Count 2580
(DOS)ABT
(DOS) NEED: 0x0000087D18-0000087D3D - 0x0005417D-0005417D Count 2D80
(DOS)CMP Count 2D80
(DOS) NEED: 0x0000083375-000008349F - 0x00054167-00054167 Count 2070
(DOS)CMP Count 2070
(DOS) NEED: 0x0000087F94-00000880BE - 0x00054180-00054180 Count 2640
(DOS)ABT
(DOS) NEED: 0x0000088036-00000880BE - 0x00054180-00054180 Count 2B00
(DOS)CMP Count 4100
(DOS) NEED: 0x0000087AE8-0000087C12 - 0x0005417C-0005417C Count 2320
(DOS)CMP Count 2320
(DOS) NEED: 0x0000087E69-0000087F93 - 0x0005417F-0005417F Count 2300
(DOS) Marginal Read: 0000087E76
(DOS)ABT
(DOS) NEED: 0x0000087F2F-0000087F93 - 0x0005417F-0005417F Count 2C00
(DOS)CMP Count 2E00
(DOS) NEED: 0x0000087892-00000879BC - 0x0005417A-0005417A Count 2290
(DOS)ABT
(DOS) NEED: 0x00000879A7-00000879BC - 0x0005417A-0005417A Count 2780
(DOS)CMP Count 2780
(DOS) NEED: 0x00000835CB-00000836F5 - 0x00054169-00054169 Count 2040
(DOS)CMP Count 2040
(DOS) NEED: 0x0000087767-0000087891 - 0x00054179-00054179 Count 2380
(DOS)CMP Count 2380
(DOS) NEED: 0x00000879BD-0000087AE7 - 0x0005417B-0005417B Count 2580
(DOS)CMP Count 2580
(DOS) NEED: 0x0000087D3E-0000087E68 - 0x0005417E-0005417E Count 27A0
(DOS)CMP Count 27A0
(DOS) NEED: 0x00000880BF-00000881E9 - 0x00054181-00054181 Count 2E60
(DOS)ABT
(DOS) NEED: 0x0000088196-00000881E9 - 0x00054181-00054181 Count 4580
(DOS)CMP Count 4580
(DOS) NEED: 0x000007B0D2-000007B1FC - 0x00054165-00054165 Count 2110
(DOS)CMP Count 2110
(DOS) NEED: 0x00000844FA-0000084624 - 0x00054176-00054176 Count 2000
(DOS)CMP Count 2000
(DOS) NEED: 0x0000087F94-00000880BE - 0x00054180-00054180 Count 2300
(DOS)CMP Count 2300
(DOS) NEED: 0x00000881EA-0000088314 - 0x00054182-00054182 Count 4300
(DOS)ABT
(DOS) NEED: 0x00000882BF-0000088314 - 0x00054182-00054182 Count 5380
(DOS)CMP Count 5380
(DOS) NEED: 0x0000088315-000008843F - 0x00054183-00054183 Count 3B80
(DOS)CMP Count 3B80
(DOS) NEED: 0x0000088440-000008856A - 0x00054184-00054184 Count 2EA8
(DOS)ABT
(DOS) NEED: 0x000008852F-000008856A - 0x00054184-00054184 Count 3E80
(DOS) Marginal Read: 0000088556
(DOS) Write Error - 0000088556.
(DOS) Marginal Read: 000008855F
(DOS) Marginal Read: 0000088560
InitiateMarkPendingReallocateRequest for disc_lba: 0000088560!
(DOS) Read Error - 0000088560
(DOS)ABT
(DOS) NEED: 0x0000088561-000008856A - 0x00054184-00054184 Count 4480
(DOS)CMP Count 4480
(DOS) NEED: 0x00000843CF-00000844F9 - 0x00054175-00054175 Count 20F0
(DOS)CMP Count 20F0
(DOS) NEED: 0x000008856B-0000088695 - 0x00054185-00054185 Count 2B80
(DOS)ABT
(DOS) NEED: 0x0000088622-0000088695 - 0x00054185-00054185 Count 3A00
(DOS) Marginal Read: 0000088668
(DOS)CMP Count 4280
(DOS) NEED: 0x0000088696-00000887C0 - 0x00054186-00054186 Count 5980
(DOS) Marginal Read: 000008877B
(DOS) Write Error - 000008877B
(DOS)ABT
(DOS) NEED: 0x0000088780-00000887C0 - 0x00054186-00054186 Count 6A00
(DOS)CMP Count 6F80
(DOS) NEED: 0x0000083821-0000083DF7 - 0x0005416B-0005416F Count 20B0
(DOS)CMP Count 20B0
(DOS) NEED: 0x0000087C13-0000087D3D - 0x0005417D-0005417D Count 20E0
(DOS)ABT
(DOS) NEED: 0x0000087CD2-0000087D3D - 0x0005417D-0005417D Count 2180
(DOS)ABT
(DOS) NEED: 0x0000087D18-0000087D3D - 0x0005417D-0005417D Count 2980
(DOS)CMP Count 2980
(DOS) NEED: 0x0000084625-000008474F - 0x00054177-00054177 Count 20A0
(DOS)CMP Count 20A0
(DOS) NEED: 0x0000087D3E-0000087E68 - 0x0005417E-0005417E Count 2300
(DOS)CMP Count 2300
(DOS) NEED: 0x00000880BF-00000881E9 - 0x00054181-00054181 Count 2340
(DOS) Refresh Start.˙
PostPosted: December 19th, 2018, 3:40
Hi
I have the same problem with my Seagate Barracuda ST2000DM001 1CH164 (Firmware CC27) (7200.14)
Disk was working on Centos - with one ext4 partition.
Few days ago, i saw bad blocks in dmesg command, disk stops responding, switched to Read Only.
I was trying to investigate state of disk but when i used fdisk command i got info i have 0 LBA.
Disk is correctly spinnig up but i can not see disk in operating system
Below info from TTL:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
(P) SATA Reset
F3 7>
ATA  15 Cmds
Ts(ms)     dT(ms)   Op Cnt  LBA
         0 99999999 00 0000 000000000000
         0        0 00 0000 000000000000
      7826     7826 EC 0000 000000000000
      9162     1336 00 0000 000000000000
RW  32 Cmds
Ts(ms)     dT(ms)   xT(ms)  Type Option Mode  St EC       Info
      6836 99999999        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.05FFFFF.03BF800
      6869       33        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
      6877        8        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003AE26 L 000000000001 BO 000000 BES 022D280.022D2BF.022D280
      6885        8        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD5 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
      6893        8        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009D917 L 000000000051 BO 000000 BES 03BF800.03C0C3F.03BF800
      6902        9        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      6911        9        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      6920        9        0 27  028201 000000 1 00000080 SND_SRV 0C01 0000 0000 0000 0000 0000 0000 0000
        0000 0000 0000 0000 0000 0000 0000 0000
        0001 C7EA 00D0
        6758 0001 0000 0006 0004 FA50 E650 E271
        0003 0FB0 0F99 0F81 0F6F 0F6B 1000 1004
        236D E62C 4E3C 57F5 CB94 7522 A454 15D5
        797E FB1E 0C27 1443 F22B BE46 2A67 F3E8
      6920        0        7 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003FDBB L 000000000001 BO 000000 BES 0068487.00684C6.0068487
      6927        7        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000423A0 L 000000000003 BO 000000 BES 00684C7.0068586.00684C7
      6935        8       13 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      6954       19      114 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003C5BB L 000000003800 BO 000000 BES 0068F67.0148F66.0068F67
      7251      297        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
      7260        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
      7268        8        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009D933 L 000000000002 BO 000000 BES 022D280.022D2FF.022D280
      7276        8        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADF1 L 000000000002 BO 000000 BES 022D280.022D67F.022D280
      7324       48        2 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADF3 L 000000000001 BO 000000 BES 00689E7.0068A26.00689E7
      7326        2        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D280.022D37F.022D280
      7334        8        9 02  011201 000000 1 00000080 XFR RD SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
      7343        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003ADD7 L 000000000004 BO 000000 BES 022D680.022D77F.022D680
      7351        8        6 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000C5684 L 000000000001 BO 000000 BES 0241A80.0241ABF.0241A80
      7364       13      176 02  011101 000000 0 43110081 XFR RD USR LBA B 000000014D2E L 000000000762 BO 24000E74 VL E89C.3B10
      7541      177       32 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000003C298 L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      7574       33       24 02  028201 000000 1 00000080 XFR WR SYS LBA B 00000009EDDA L 000000000308 BO 000000 BES 03B3600.03BF7FF.03B3600
      7599       25        4 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      7603        4        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      7613       10       36 02  011101 000000 1 00000080 XFR RD USR LBA B 000000000000 L 000000000198 BO 24000E74 VL 2C9C.0CC0
      7739      126       18 02  028101 000000 1 00000080 XFR WR USR LBA B 000000000000 L 000000000198 BO 24000E74 VL 3C9C.0CC0
      7758       19       27 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
      7786       28        8 02  011201 000000 1 00000080 XFR RD SYS LBA B 0000000373D5 L 000000000001 BO 000000 BES 00650DD.006511C.00650DD
      7794        8        9 02  028201 000000 1 00000080 XFR WR SYS LBA B 0000000352F6 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
      7803        9        8 02  028201 000000 1 00000080 XFR WR SYS LBA B 000000097E38 L 000000000008 BO 000000 BES 0068D27.0068F26.0068D27
     V1:
     Head 0: entries    38C        slips      AC1
Head 1: entries    3D4        slips     46C9
Head 2: entries    C77        slips     8890
Head 3: entries    DDF        slips     E88A
  Total Entries   21B6  Total Slips    1C2A4
      V3:
  F3 T>V40
Nonresident GList                    0 entries returned
Total entries available: 0
          PBA           Len  Flags  Phy Cyl Hd  PhySctr    SFI
Is any chance to recover data from this disk?
Are these commands are useful in my case:
/T
i4,1,22
F009A,C1
F00E2,91
F00EC,B0
/1
N1
Users browsing this forum: No registered users and 69 guests
