 Post subject: WD passport 500gb broken tracks of usb
PostPosted: November 9th, 2010, 20:29
Hello! My first post! :)
I received today a WD my passport 500gb with broken usb connector and failed initio ic. I am trying to do the sata cable, but i cannot power up the disk since the +5v track is destroyed (don't ask me how...). Is there any testpoint or other place to give the disk power? I cannot track it by myself...
Thanks a lot!
 Post subject: Re: WD passport 500gb broken tracks of usb
PostPosted: November 9th, 2010, 21:00
does your PCB beside USB connector has 12 Pins? you can give power there if so. i try it before. :D but the point is you need to make it a connection with SATA interface for access data. do you have experience on kind of soldering work?
data recovery service[/b]
PostPosted: November 9th, 2010, 22:18
It might be helpful here if you show us a picture to see the extent of damage
PostPosted: November 10th, 2010, 5:13
Here is the photo : Image
Uploaded with ImageShack.us
I've already soldered the cables and sata connector :) . The drive does have the 12 pin connector!
PostPosted: March 10th, 2012, 0:20
I have similar problems. I have done sata connection.
but when you connect sata drive good read. but encrypted.
Does anyone have no solution.
Chip encoding: sw6316-3vb14 symwave
DATA RECOVERY SERVICE VIETNAM
Cứu dữ liệu ổ cứng| Cứu dữ liệu máy chủ |Phục hồi dữ liệu
PostPosted: March 12th, 2012, 0:22
every one have solution . Please help me
PostPosted: March 12th, 2012, 4:36
Assuming that the original problem was a connector issue, then repairing the physical damage would be the most prudent approach. Use wirewrap wire if necessary.
PostPosted: March 12th, 2012, 5:35
for now. i plugin my laptop. it request format . and auto reset and detect again.
huhuhu
PostPosted: March 12th, 2012, 20:38
If you are connecting via SATA, then your data will be encrypted. That's why your OS is not seeing the file system.
PostPosted: March 13th, 2012, 1:46
No , encrypted via usb controler chip. conecting via sata is skip usb controler chip .
PostPosted: March 13th, 2012, 10:13
still encrypted if you bypass the usb connector with a sata bridge.
PostPosted: March 13th, 2012, 18:49
When your OS writes to the drive, the USB-SATA bridge IC encrypts the data. Therefore, when you read data back from the drive, you need the same bridge IC to decrypt it.
Use a hex editor to view sectors 0 and 1. Then you'll understand what is happening.
Here are two free tools:
HxD - Freeware Hex Editor and Disk Editor:
http://mh-nexus.de/en/hxd
DMDE (DM Disk Editor and Data Recovery):
http://softdm.com/download.html
PostPosted: March 14th, 2012, 1:13
Good dayy.
I have success fix it.
I have done.
Simple. I right click on the drive select offline
Machine hangs a few seconds. Then I unplug the cable. and reconnecting. received but drive in read only mode. I use R-studio and copy all the.
but I still do not understand
PostPosted: January 4th, 2019, 3:14
for 2017 PC3000 have decrypt data mode. it very usefull.
Users browsing this forum: Google [Bot] and 43 guests
