 Post subject: WD 4TB USB don't read ROM after PCB change
PostPosted: January 6th, 2019, 7:48
I have a USB WD drive that had a problem in PCB, the customer bought a new drive with same model ID/PCB ID. I moved ROM the the good PCB and drive start working correctly.
The customer left me the HDA (of the new drive), I bought the same PCB REF: 2060-800041-003 REV P1 and I moved ROM to the new bought PCB.
Now, the drive spin well, Reaches readiness and run in Normal mode. it can read Model/Capacity/SA SPT, but doesn't read ROM. here what it shows in terminal:
Techno mode key......................... : Ok
Debug Stop Code reading................. : No data been read
RAM:
SA HDD has unknown capacity. SA CHS access may operates wrongly
HDD Info reading........................ : Ok
Heads number............................ : 10
Cyl Count............................... : 384
Zone allocation table................... : Ok
SA SPT.................................. : 2140
ROM:
Read ROM................................ : HDDs ROM reading error; unexpected error: Data request error; unexpected error: Abort command : No Additional Sense Information
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Module ID 02 reading error; unexpected error: Data request error; unexpected error: Abort command : No Additional Sense Information
what could be the problem, Security or ROM? is there a way to correct this to have a Working drive?
Thanks in advance for your help,
 Post subject: Re: WD 4TB USB don't read ROM after PCB change
PostPosted: January 7th, 2019, 9:25
Why do you think drive is not working ?
Angel Data Recovery
PostPosted: January 7th, 2019, 10:17
Thank you for your reply.
Drive (HDA) works for sure (its a new drive). and PCB works too.
I checked the PCB I bought and I found that its for 3TB WD drive (but same PCB Reference).
PC-3000 support said that the Firmware is locked.
drive is not recognized in Windows (can't be initialized).
and in PC3000 drive can't read ROM and read sectors.
Users browsing this forum: Google [Bot] and 43 guests
