Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
 Post subject: Re: Deformation of dishes?
PostPosted: December 10th, 2018, 5:20
I have collected some information about shock sensors, particularly those made by Murata.
Hard drive shock sensors:
http://www.hddoracle.com/viewtopic.php?t=2637
PostPosted: December 10th, 2018, 22:40
mhp666 wrote:
In none of these cases there were scratches on the HDD, so I assumed that it is due to deformations in the dishes.
2.5" platters are made of glass, deformation is highly unlikely, even if some "potato chip" effect can be observed, it's probably minimal and can be ignored
the WD model you have has special servo-to-data position calculation that depends greatly on original bearing being intact, which is often not the case on old or even dropped drives.
Very possible that vibrations you applying move disks packet inside the bearing just enough to bypass the read errors. Keep in mind that vibrations could cause heads to come near or even touch the surface, which is not a good thing.
PostPosted: December 11th, 2018, 17:50
Thank you for this clarification I had not thought about this detail.
I think they are usually made of aluminum, and there were a number of HDDs that were made of glass and that had more drawbacks than advantages.
I totally agree, right now what I'm doing is very risky, I've only used it 3 times and when I did not know another way to read the sectors that I had left. In the last I spend a little and stick heads to the dishes.
PostPosted: December 11th, 2018, 17:58
I would be really surprised if you can find 2.5" drive with aluminum platters
PostPosted: December 11th, 2018, 18:08
Thanks for the clarification and sorry for my confusion.
You're absolutely right I just checked with 3 HDDs and all three of glass.
PostPosted: December 11th, 2018, 18:55
I don't know how accurate it is, but SA module C5h contains DCM information, including heads, media and preamp vendors and part numbers.
http://www.hddoracle.com/viewtopic.php?f=86&t=1036&p=4555
PostPosted: December 11th, 2018, 19:28
Very good work
PostPosted: December 12th, 2018, 8:05
When this problem happens again, I will try to change the dishes to another HDD, to see if it reads those sectors without problems and the deformation of the dishes could be discarded.
Thanks again for the indication.
PostPosted: January 16th, 2019, 17:19
It seems that I am again faced with an HDD that may be that the bad sectors are read with vibrations (I'm not sure, at the moment I'm taking out the information).
I put a picture of the vibrators that I got to perform the test. They are stuck only by the front to the HDD.
PostPosted: January 16th, 2019, 17:35
@mph666, what were the vibrators removed from or from what were the constructed?
PostPosted: January 16th, 2019, 17:45
I bought them on Aliexpress.
https://es.aliexpress.com/item/DC-12-V- ... 63c07apijP
I hope to be able to do a test with the HDD that I am recovering, because it has all the looks to be a candidate.
PostPosted: January 16th, 2019, 20:50
Thanks. Good luck with your experiment!
PostPosted: January 19th, 2019, 5:23
I just tested the vibrations in a HDD WD10JMVW and they do not help me to finish reading the approximately 64k sectors that it reads with errors.
Any ideas to try to recover these sectors?
2019-01-19 at 10-18-38.png [11.71 KiB]
Not downloaded yet
PostPosted: January 19th, 2019, 16:01
Spildit wrote:
Can you tell use the full models of the drives where vibration did actualy helped you out to recover the data ?
If in the last 2 cases I had, if I managed to recover the data 100%. In one of them I think I remember that there were about 2400 sectors and I read them in less than 1 minute.
In this case where I am I can not recover a single sector, I will wait for an HDD to come out with these conditions and I will try to draw conclusions.
Greetings.
PostPosted: January 21st, 2019, 10:47
I do not remember the HDD models (badly done by me).
But I think it happened to me with wd and toshiba.
