 Post subject: About S.A : where is it located ? it's essential ?
PostPosted: February 1st, 2019, 13:40
I know that for many it will be a stupid question, but on hard drives with multiple platters :
1- Is the SA located in several platters or in only one?
2- Is it essential to read it in order to boot a hard drive?
 Post subject: Re: About S.A : where is it located ? it's essential ?
PostPosted: February 1st, 2019, 13:53
usually one platter but both sides
it is essential for a drive to read SA in order to boot
PostPosted: February 1st, 2019, 14:34
And you can not crack the firmware so that it does not go to look for the SA?
PostPosted: February 1st, 2019, 15:15
The firmware IS on the SA (Service Area), well the vast majority of it is. Specifically the useful stuff like defect tables, translator, head tuning adaptives etc....
PostPosted: February 1st, 2019, 15:17
Hmmm. Sounds anti-data recovery.....
PostPosted: February 1st, 2019, 15:24
jajaj no no, I'm just learning about hard drives, and I wanted to know how indispensable it really is the SA that is on the hard disk platters for a recovery.
Imagine that just the SA has a scratch, Game over?
You can´t avoid it ?
PostPosted: February 1st, 2019, 15:28
The SA is stored in at least two places (sometimes 4) on modern drives. Some of the FW is unique to the drives such as the translator and if those unique parts are lost then the drive is toast, but some FW is interchangeable. All depends on what area is corrupt.
PostPosted: February 3rd, 2019, 14:19
Thanks very much for the info. I will read it.
PostPosted: February 3rd, 2019, 17:17
newbie info, from and for newbies :) About firmware, SA, etc:
https://forum.hddguru.com/viewtopic.php?f=16&t=6562
PostPosted: February 4th, 2019, 6:56
After reading all the links I still have the doubt of whether reading the information contained in the SA (on the platters) is absolutely essential to read and interpret the data on a hard disk or on the contrary it can be "bypassed" by modifying the firmware of the PCB.
That is, if the sectors of the platter( or platters ) where the S.A is is completely destroyed (headcrash for example) make it necessary to give up.
I also understand that certain brands, such as Toshiba, that have an exclusive firmware for each specific unit, will look for the password in or certain vital information to confirm that this platter belongs from that drive, therefore accessing the S.A would be something vital. But in other models I understand that no ..¿ im right ?
PostPosted: February 4th, 2019, 7:43
For example SMART and G-list :
Are they completely indispensable and unique to each unit?
PostPosted: February 4th, 2019, 10:05
Better go back and read it all again, but this time slow down by a factor of 10 and try to actually understand what you're reading.
If the SA is completely destroyed, it's unrecoverable 100% of the time. There's nothing to even bother attempting.
There's very little firmware on the PCB beyond what it needs to be able to read the SA, where the other 99% of the firmware code is stored. Including all the drive specific adaptives, translation, etc. etc. etc. Rebuilding all of this from scratch would be the equivalent of guessing a 1,000,000 digit long password. It's never going to happen.
No, all modern drives have parts of the firmware that are drive specific. In fact, most drives now have a whole lot of firmware data that is drive specific and most of it (sometimes all) is actually stored in the SA. Toshiba is actually different in the fact that a higher percentage of the drive specific adaptives are stored as configuration pages on the ROM of the PCB instead of the platter SA. So Toshibas are less susceptible to firmware corruption for this reason.
PostPosted: February 4th, 2019, 10:21
No. They're unique to each unit, but not indispensable. Those can both be cleared.
But the P-List, T-List, Translator, SED modules, head adaptives, service area adaptives, head adaptives, RAP, CAP, service area translator, and many many other modules are completely unique and are indispensable in many cases.
PostPosted: February 4th, 2019, 10:29
I still think this post is about anti-data recovery.
PostPosted: February 4th, 2019, 10:35
Perhaps. Clearly, it's by someone with a vastly over-simplified concept of how a HDD works.
PostPosted: February 4th, 2019, 14:25
I'm not a professional, but I like this topic as a hobby. That's why I do not understand many things and I ask.
Thanks a lot for the info data-medics :wink:
Users browsing this forum: No registered users and 57 guests
