 Post subject: NEED FIRMWARE OF THE SEAGATE ST1000VM002 1CT162-500 SC23
PostPosted: March 3rd, 2018, 21:36
NEED FIRMWARE OF THE SEAGATE ST1000VM002 1CT162-500 SC23 THE SAME AND DVR AND IF IT IS LOCKED I NEEDED A FIRMEWARE UNLOCKED THANK YOU WHO CAN SEND ME
 Post subject: Re: NEED FIRMWARE OF THE SEAGATE ST1000VM002 1CT162-500 SC23
PostPosted: March 3rd, 2018, 21:39
Firmware will not help you
PostPosted: March 4th, 2018, 11:23
why you need Firmware and what kind of lock you talk about in this BACALL HDD ?
http://www.hpwlab.com
PostPosted: February 6th, 2019, 6:45
Banned User
Spildit wrote:
Firmware for what tool ? PC-3000 ? :shock: :shock: :shock:
Drive can be unlocked but you need at least a TTL adaptor and some firmware tools (expensive)...
ca you help me? i have same model locked...thanks in advance!
https://t.me/pump_upp
PostPosted: February 6th, 2019, 8:42
Este é o seu segundo post neste fórum solicitando um firmware sem dar qualquer indício sobre o problema no HD. Em outra postagem já foi informado que para destravar um HD travado por DVR seria necessário equipamento especializado e (caro).
Não sei se tem mais alguém neste fórum do Brasil, mas eu tenho uma MRT Express e poderia fazer este serviço se acaso os dados forem importantes. Se não forem, o custo de envio e retorno para minha localidade provavelmente será maior que o valor do HD.
This is the second post from same user (on first he was speaking in portuguese, that's why i wrote it above) in this forum asking a firmware without any information about the HDD's problem. On that time you were informed that only a firmware would not help to unlock a DVR locked HDD, and it would require expensive tools.
Don't know if there is another user here from Brazil, but I have a MRT Express and could do this job if the Data on this is important. If not, the costs to ship it to me and give you back probably will be greater than HDD's value.
Users browsing this forum: Google [Bot] and 46 guests
