 Post subject: probelm with WD20EFRX
PostPosted: June 7th, 2019, 3:54
hi,
i have a pair of WD20EFRX-68EUZN0, same firmware 82.00A82, same date 22 feb 2017.
one of them works , only weak head 3 but id and read all
other one id but no data access ( tested with rapidspar ).
with WDR Pro hangs forever when try to id
try in safe mode TV9-TV10 sometime id correctly and sometime id with random data, also when id correctly access to SA, backup rom or any other operations result in completly freeze. When id with Diablo 3S and 0 capacity i can only read 0001 Dir module, any other module return error, read and/or write.
try to swap pcb/rom and head with other drive but same problem.
any advice how to proceed ( i only have WDR Pro 6 and Rapidspar, no other tools at moment )
 Post subject: Re: probelm with WD20EFRX
PostPosted: June 7th, 2019, 7:30
Spildit wrote:
You shouldn't be using WDR anymore. It doesn't work with modern drives.
This is not true. One just have to change the format of module 01 (Dir) from new to old....
And, by the way, the OP is using WDR Pro , not WDR...That's bad.
PostPosted: June 7th, 2019, 9:48
i think this has firmware issue. sometimes SA damaged. i think first, you have to identify exact problem.
try to SA bypass by modifying ROM.
otherwise try to contact DR PROFFESIONAL as SPILDIT told.
PostPosted: June 7th, 2019, 11:47
@maxisvk
Download WDMarvel demo from:
https://wdmarvel.com/en/
Learn how to use it and try to read all modules, ROM and regions. First on the good drive and then on the bad. Post the results and we'll see what to do next.
@Spildit
Yes , I could fix the drive with WDR. Be sure.
PostPosted: June 7th, 2019, 13:29
thanks for all reply.
this work is mostly for learning so is not a case that we go to pro.
about WDR yes, i use WDR Pro, i use it in past to fix sa module but never experience problem like this.
we have hepa clean room and all tools form apextoollab and er-tools. Yes, i'm not PRO for sure, but i have some experience in last year and when i think is too hard for me i always send it to PRO.
@BGman
i try now with WDMarvel demo, thanks
PostPosted: June 10th, 2019, 5:24
with WD Marvell 4:
donor read rom, modules and region, thisi is the log:
07/06/2019 20.11.24: Drive: WDC WD20EFRX-68EUZN0, family: Diablo 3S (Royl), FW: 01.AVC, SN: WD-WCC4M3AZDT6P, LBA 3907029168 - 2000Gb
07/06/2019 20.11.43: ROM successfully read
07/06/2019 20.11.50: Reading modules...
07/06/2019 20.12.30: Error reading module ID1531, state - FM_ERR_CHECKSUM
07/06/2019 20.13.06: Successfully read 482 modules
07/06/2019 20.16.01: Region 0 read
07/06/2019 20.18.35: Region 1 read
patient drive instead read rom, partial modules and no regions, log:
10/06/2019 11.11.49: Drive: WDC WD20EFRX-68EUZN0, family: Diablo 3S (Royl), FW: 01.AVC, SN: , LBA 0 - 0Gb
10/06/2019 11.12.16: Reading modules...
10/06/2019 11.12.17: Error reading module ID02, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.26: Error reading module ID11, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.26: Error reading module ID1B, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.27: Error reading module ID21, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.27: Error reading module ID23, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.27: Error reading module ID24, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.27: Error reading module ID2A, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.28: Error reading module ID2F, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.32: Error reading module ID50, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.32: Error reading module ID51, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.32: Error reading module ID52, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.32: Error reading module ID53, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.32: Error reading module ID5C, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.33: Error reading module ID6D, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.33: Error reading module ID6E, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.34: Error reading module ID81, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.35: Error reading module IDB5, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.38: Error reading module IDE0, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.38: Error reading module IDE1, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.39: Error reading module IDE2, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.39: Error reading module IDE3, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.39: Error reading module IDE6, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.39: Error reading module IDE8, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.39: Error reading module IDE9, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.40: Error reading module IDEA, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.40: Error reading module IDEB, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.41: Error reading module IDFE, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.41: Error reading module ID108, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.41: Error reading module ID109, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.41: Error reading module ID115, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.41: Error reading module ID116, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.41: Error reading module ID118, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.45: Error reading module ID122, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.45: Error reading module ID131, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.45: Error reading module ID144, state - FM_ERR_CHECKSUM
10/06/2019 11.12.46: Error reading module ID411, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.47: Error reading module ID1102, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.47: Error reading module ID1106, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.48: Error reading module ID120F, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.48: Error reading module ID1410, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.48: Error reading module ID1531, state - FM_ERR_CHECKSUM
10/06/2019 11.12.48: Error reading module ID1803, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.49: Error reading module ID1900, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.49: Error reading module ID1901, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.54: Error reading module ID250A, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.55: Error reading module ID250C, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.55: Error reading module ID250E, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.55: Error reading module ID2514, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.55: Error reading module ID251A, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.55: Error reading module ID251E, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.56: Error reading module ID2522, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.56: Error reading module ID2529, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.57: Error reading module ID252C, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.57: Error reading module ID252D, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.57: Error reading module ID2670, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.57: Error reading module ID2671, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.57: Error reading module ID2672, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.57: Error reading module ID2673, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID2690, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID2691, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID2692, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID2693, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID26D0, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID26D1, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID26D2, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.12.58: Error reading module ID26D3, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.00: Error reading module ID2D07, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.00: Error reading module ID2D09, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.01: Error reading module ID2D0A, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.01: Error reading module ID2D0C, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.02: Error reading module ID2D0E, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.02: Error reading module ID2D14, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.03: Error reading module ID2D1A, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.03: Error reading module ID2D1E, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.04: Error reading module ID2D22, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.04: Error reading module ID2D29, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.04: Error reading module ID2D2C, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.04: Error reading module ID2D2D, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.13: Error reading module ID3803, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.13: Error reading module ID3C12, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.14: Error reading module ID3E01, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.14: Error reading module ID3F03, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.14: Error reading module ID3F04, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.14: Error reading module ID3F06, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.16: Error reading module ID4002, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.17: Error reading module ID801E, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.20: Error reading module IDAC55, state - FM_ERR_HEADER_II_SIGNATURE_INVALID
10/06/2019 11.13.20: Successfully read 396 modules
reading regions results for all sector: Error reading RLBA sector xxxx, state - VSC_ERR_UNSUP_ACTION_CODE
PostPosted: June 10th, 2019, 7:04
solved with WD Marvell, follow this thread http://www.hddoracle.com/viewtopic.php?f=193&t=2339
i use overlay from patient then restore damaged module, now drive is imaging at full speed
PostPosted: June 10th, 2019, 10:38
Congratulations.
Sexy Womans from your town
PostPosted: June 10th, 2019, 11:15
goodluck
PostPosted: June 11th, 2019, 3:15
It looks like that mod 01 (Dir) was damaged.
Users browsing this forum: No registered users and 33 guests
