 Post subject: Best internal HDD for a beginner?
PostPosted: June 12th, 2019, 1:30
Banned User
Hello everyone,,
So I want to join the ranks of data hoarders - I have always been one at heart but right now my files are stored on a pretty classic setup, a 120 GB WD Green SSD + 1 TB WD Blue HDD, and I am running out of space.
I am considering either a 2 TB WD Red or a 2 TB Seagate Ironwolf. I can't shuck bigger capacity WD Easystores because apparently these are not available in my country and other WD external drives of that size cost almost $500. However in the case of both drives I read a lot of reviews complaining about bad sectors so I am unsure which one I should get. I am considering a WD Black as an alternative. I don't really care about noise. What would you recommend?
 Post subject: Re: Best internal HDD for a beginner?
PostPosted: June 12th, 2019, 8:46
Lincon12 wrote:
Hello everyone,,
actually I would recommend google drive or similar. As you don't mention backups, then one bad luck incident, no matter what you choose, means everything gone.
Probably another WD Blue or black will be quite fine for you.
Users browsing this forum: Majestic-12 [Bot] and 45 guests
