Sector 0 looks like an MBR when it is dword-reversed. However, it does not follow the MS standard.
000001C0 00 00 0C 00 00 00 00 00 00 10 00 20 00 00 00 00
000001D0 00 00 0C 00 00 00 00 20 00 10 12 81 9E A0 00 00
000001E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
000001F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA
There appear to be two FAT32 partitions (ID = 0x0C).
The first begins at sector 0x10 and has a size of 0x200000 sectors.
The second begins at sector 0x200010 and has a size of 0x12819EA0 sectors.
The total size is 0x200010 + 0x12819EA0 sectors = 160.04 GB
Similarly, sector 0x10 looks like a FAT32 boot sector when it is reversed, but once again it does not totally follow the MS standard (eg the FSINFO sector pointer is 0x100 instead of 1).
The text strings are little-endian dwords. FAT64 = exFAT.
HUMAX 0.1
HUMAXI-CORDFAT64<3 spaces>
The signature is "FAT64", but the sector doesn't look like an exFAT boot sector:
https://www.ntfs.com/exfat-boot-sector.htmoriginal
00002000 48 00 00 E9 58 41 4D 55 02 31 2E 30 84 00 08 00 H..éXAMU.1.0„...
00002010 00 00 00 01 00 00 F8 00 02 00 20 00 00 00 20 00 ......ø... ... .
00002020 00 00 20 00 FF 07 00 00 00 00 00 00 02 00 00 00 .. .ÿ...........
00002030 06 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00002040 00 29 00 00 48 00 00 00 58 41 4D 55 4F 43 2D 49 .)..H...XAMUOC-I
00002050 41 46 44 52 20 34 36 54 00 00 20 20 00 00 00 00 AFDR 46T.. ....
reversed
00002000 E9 00 00 48 55 4D 41 58 30 2E 31 02 00 08 00 84 é..HUMAX0.1....„
00002010 01 00 00 00 00 F8 00 00 00 20 00 02 00 20 00 00
00002020 00 20 00 00 00 00 07 FF 00 00 00 00 00 00 00 02
00002030 00 01 00 06 00 00 00 00 00 00 00 00 00 00 00 00
00002040 00 00 29 00 00 00 00 48 55 4D 41 58 49 2D 43 4F ..)....HUMAXI-CO
00002050 52 44 46 41 54 36 34 20 20 20 00 00 00 00 00 00 RDFAT64 ......
000021F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 55 ..............ªU
There appears to be only 1 copy of the FAT.
Logical sector 6 appears to be a copy of the boot sector.
The 32-bit FAT is located at logical sector 0x84, ie physical sector 148 (= 0x84 + 0x10).
The number of sectors per FAT appears to be 0x7FF.
First sector of FAT (not reversed)
Offset(h) 00 04 08 0C
00012800 F8FFFF0F FFFFFF0F FFFFFF0F FFFFFF0F
00012810 FFFFFF0F FFFFFF0F FFFFFF0F FFFFFF0F
00012820 09000000 0A000000 DD2E0000 FFFFFF0F
00012830 FFFFFF0F FFFFFF0F FFFFFF0F FFFFFF0F
00012840 FFFFFF0F FFFFFF0F FFFFFF0F FFFFFF0F
00012850 FFFFFF0F FFFFFF0F FFFFFF0F FFFFFF0F
00012860 FFFFFF0F FFFFFF0F 1B000000 1C000000
00012870 1D000000 1E000000 1F000000 20000000
00012880 21000000 22000000 23000000 24000000
00012890 25000000 26000000 27000000 28000000
000128A0 29000000 FFFFFF0F 2B000000 2C000000
000128B0 2D000000 2E000000 2F000000 30000000
It would appear that Humax uses a hybrid FAT32 system and deviates from the MS standard by mixing up the endianness of the various file system components.
There is an unusal structure at physical sector 0x30.
00006000 00100000 00000000 00000000 5E000000
00006010 00000000 8B080000 01000000 00000000
00006020 00000000 01000000 01000000 01000000
00006030 00000000 07000000 01000000 02000000
000065F0 03020100 07060504 0B0A0908 0F0E0D0C
Sector 0x33 has a directory segment which looks out of place.
Normally one would expect to find the root directory just after the last FAT. In the case of the first volume I would expect to find it at sector 2195 (= 148 + 0x7FF).
That said, the user's data would probably be located at sector 0x200010. It could very well be that the data are dword reversed, in which case one would need to reverse the entire 160GB user area before performing a raw scan.
