 Post subject: ST500LM000 - determine PREAMP VALUE ?
PostPosted: October 1st, 2019, 10:16
who can determine the right PREAMP value (see my patient ROM file).
May be with PC-3000 or MRT .....
(Terminal not work -> CTRL + L, hdd is damaged!)
Thanks for help!
STR_ST500LM000_Patient_ROM.zip [650.63 KiB]
Downloaded 507 times
 Post subject: Re: ST500LM000 - determine PREAMP VALUE ?
PostPosted: October 1st, 2019, 10:26
Looks like D0 00
http://www.rescue-it.se
PostPosted: October 2nd, 2019, 6:48
Thanks for help!
I can not find a hdd with the right preamp value.
I could get donor drives with D0 74 / D0 67 and so on (D0 XX serie).
Whats are your experiences with this hdd ?, other persons says take any hdd with D0 and XX value).
PostPosted: October 2nd, 2019, 7:22
Any D0 XX should work just fine.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: October 2nd, 2019, 9:46
pre amp value indicated in your rom is D0 00
My firmware database:
PostPosted: October 2nd, 2019, 11:14
Thanks to mr_spokk, digisupport and michael chiklis.
I will test new heads with a D0 XX PREAMP.
Question the PREAMP bytes are not a fixed offset !? (as far as I know).
How can i calculate the right position ?
Or is the right position in a another byte offset like MR jogs (WD - mod. 47 0x20).
Thanks for any info.
PostPosted: October 2nd, 2019, 13:25
+1 agree
PostPosted: October 2nd, 2019, 16:28
Locating the preamp ID in a Seagate F3 ROM:
http://www.hddoracle.com/viewtopic.php?f=59&t=2173&start=60#p18028
PostPosted: October 4th, 2019, 11:43
Thanks, i find the oracle post yesterday.
I find now a compatible head-stack, and can copy data.
But i have to many read errors (heavy head-stiction) and can not clear the g-list.
Media cache and so on are disabled, i have the mods, but can not copy0 sys file 1b
(copy1 are ok).
Thanks for any help!
Terminal output:___________
F3 T>i4,1,22
i4,1,22
RECOV Servo Op=0055 Resp=0005
SIM Exception Code: 0005
LED:000000BC FAddr:0000905B
Rst 0x40M
Servo Processor Is Reset.
Spin Up
Spin issued
RECOV Servo Op=0100 Resp=0005
TCC:001C
RECOV Servo Op=0165 Resp=0005
PostPosted: October 4th, 2019, 12:49
Try clone one head at the time, maby head 0 need another swap?
Users browsing this forum: No registered users and 47 guests
