 Post subject: Drive giving errors:
PostPosted: March 30th, 2005, 23:35
Hi :
Got Toshiba mk3021gas drive. it has good pcb, hda ( tested ) bios sees it , but give all errors while cloning..... no password protected. any clue or help will be appreciated.
 Post subject:
PostPosted: March 31st, 2005, 1:09
Do you have PC3000? If yes, try reading at least one sector. Watch the error status. If it shows you ERR ABT - it _IS_ password protected.
 Post subject:
PostPosted: March 31st, 2005, 9:06
I have seen before Toshiba drives that get locked but with no password set. (In security status, it shows locked and no password set) I don't know if it's the same problem fuzzy have, but how you can unlock a drive if no password was set? I think it's some kind of firmware corruption, I don't know. I've tried all methods to unlock I can figure out (even the obvious ones, like try without password) but no solution at this time. Drive only gives ABRT with every command I send...
 Post subject:
PostPosted: March 31st, 2005, 21:00
Yes Keiv.. you are right.. that exact it is doiing... i also did everything possible, but no avail,.. i did change hda, pcb exact, pcb swap. nothing works. so there is no way it could be unlocked ......
 Post subject:
PostPosted: April 1st, 2005, 1:38
Toshibas 2.5" will be the next "maxtor athena"
Very easily they get SA corrupted, but you will have to wait for PCI PC3K to fix it ...
Regards,
-BR-
 Post subject:
PostPosted: April 1st, 2005, 2:07
Hi!
Weeks ago I use remote Repair station at http://hdd-tools.com to fix
two Toshibas 60 and 40 gb. All data was saved.
 Post subject:
PostPosted: April 1st, 2005, 6:08
Confirm. You can try with it.
 Post subject:
PostPosted: April 11th, 2005, 7:10
goodguy wrote:
Hi!
I've tried to UNLOCK WD hdd with it and after hdd has been examined, program told me that it CAN unlock my hdd, but I have to buy any of their so called "plans" to enable unlocking function.
The question is: Is it really worth to buy it? Can they really unlock my hdd via some remote modules? Has anyone tried this?
 Post subject:
PostPosted: April 11th, 2005, 9:53
Again, confirm. It can work in most cases. I used it and it worked, not on that model, but worked. You can choose a simply plan and try.
Users browsing this forum: Google [Bot] and 76 guests
