 Post subject: Samsung ST1000LM024
PostPosted: November 4th, 2019, 13:49
Samsung ST1000LM024 drive as patient.
Drive spins ok. Message in terminal is something about stuck but heads are not stuck on the platters.
Patient Drive - Donor PCB - Patient HDA - Patient ROM = same problem. (so it's not pcb related)
Patient Drive - Patient PCB - Donor HDA - Patient ROM = same problem. (good donor hda produce same result as not working)
Donor Drive - Donor PCB - Patient HDA - Donor ROM = OK (patient heads are OK)
So it remains to be platters which under microscope inspection looks like they have minor scratches but could be unfortunately in the SA area and preventing boot up process.
It also could be corrupted rom content which i suspect more. I need help from someone able to check my rom.
2BA2gbuM_d61.rar [167.86 KiB]
Downloaded 333 times
Terminal looks like this:
ActiveFW : 00
FWVer : 0001
SATA PLL cal done
DDR size detected = 8MB
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI Found
*PAUNI_L2957*PA VID=0006 PN=0009 Rev=0002- PA_UNI FoundU
S_0:19
SO_1
SPU@29'C,4950mV
IS=3
CLA ..36/79
HO..OK
HO RPM=663 OK
AC 1375
ST..OK
mS1 00000003
GT:420
SC(L):4111/45
BE.N:18
LD..Stuck
UD..OK : 45
PK_3 C: 0 H:0
GT:421
SC(L):4109/35
BE.N:18
LD..Stuck
UD..OK : 35
PK_3 C: 0 H:1
GT:421
SC(L):4107/72
BE.N:22
LD..Stuck
UD..OK : 72
PK_3 C: 0 H:2
GT:422
SC(L):4108/52
BE.N:23
LD..Stuck
UD..OK : 52
PK_3 C: 0 H:3
GT:423
SC(L):4108/31
BE.N:16
LD..Stuck
UD..OK : 31
PK_3 C: 0 H:0
GT:423
SC(L):4105/52
BE.N:22
LD..Stuck
UD..OK : 52
PK_3 C: 0 H:1
GT:424
SC(L):4112/34
BE.N:16
LD..Stuck
UD..OK : 34
PK_3 C: 0 H:2
GT:424
SC(L):4110/53
BE.N:19
LD..Stuck
UD..OK : 53
PK_3 C: 0 H:3
GT:424
SC(L):4110/70
BE.N:23
LD..Stuck
UD..OK : 70
PK_3 C: 0 H:0
GT:425
SC(L):4107/37
BE.N:17
LD..Stuck
UD..OK : 37
PK_3 C: 0 H:1
GT:425
SC(L):4110/57
BE.N:18
LD..Stuck
UD..OK : 57
PK_3 C: 0 H:2
GT:425
SC(L):4112/73
BE.N:23
LD..Stuck
UD..OK : 73
PK_3 C: 0 H:3
GT:426
SC(L):4112/29
BE.N:19
LD..Stuck
UD..OK : 29
PK_3 C: 0 H:0
GT:426
SC(L):4112/43
BE.N:18
LD..Stuck
UD..OK : 43
PK_3 C: 0 H:1
GT:426
SC(L):4111/54
BE.N:17
LD..Stuck
UD..OK : 54
PK_3 C: 0 H:2
GT:426
SC(L):4107/59
BE.N:20
LD..Stuck
UD..OK : 59
PK_3 C: 0 H:3
UDed
PK_4 C: 0 H:0
UDed
PK_4 C: 0 H:0
LED 1102
LED 1102
LED 1102
Thanks.
 Post subject: Re: Samsung ST1000LM024
PostPosted: November 4th, 2019, 14:55
Try to start the drive from other head
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: November 4th, 2019, 16:03
SHTR User Manual:
http://www.hddoracle.com/download/file.php?id=9235 (EN)
http://www.hddoracle.com/download/file.php?id=9236 (RU)
LED 1102 = All Head Fail
Users browsing this forum: Majestic-12 [Bot] and 86 guests
