 Post subject: Platter cleaning
PostPosted: December 21st, 2019, 13:14
Hello, I saw today a video (https://www.youtube.com/watch?v=afUdR6c8ikY) which blow my mind a bit and there is all done what i where thinking you can not do...
1) How he can extract all 3 platters and rotate them around - I was thinking they have to stay precisely aligned to each other?!
2) He just scrub with the broken head-assambly some particles off - in my opinion it looks quite rough to me.
You can really handle platters that way?
The machine looks like the APEX Platter Extractor but i where thinking that can be used only for drives with one platter...
 Post subject: Re: Platter cleaning
PostPosted: December 21st, 2019, 14:43
You can see a basic explanation here: Embedded Servo. You can expand your search from there.
Blizzard Data Recovery
PostPosted: December 21st, 2019, 15:14
I started a log of platter transplants without alignment here
- https://www.recoveryforce.com/forums/vi ... .php?t=565
PostPosted: December 21st, 2019, 15:29
What blows my mind is the fact that "alignment" is necessary at all. An embedded servo by definition is self-aligning. AISI, it's just another case where the engineers have screwed up.
PostPosted: December 21st, 2019, 16:33
... I see - looks like for some drives the alignment is not important but how to check if it is or not? Is there a complete list or do I need to find it out on my own?
Apropos extracting platters - I found that tool: https://www.youtube.com/watch?v=w3bt5yNt3xY
Does someone know that one and is it useable?
Are there some Books or Videocourses which you could recommand me? I found one from Scott Moulton (myharddrivedied.com) but if the videos are the same as on youtube i am affraid I will not learn much...
PostPosted: December 26th, 2019, 10:38
Maddin ,
I Would Like To Answer Your question 1 by 1
1 : Platter Alignment is req in some drive and not in others ,Also you can work about firmware to solve alignment issue if you know how
2 :I did not like what erkin did to remove the stuck part ,A better approach would have been you use a fishing line or nylon thread and take the same apart .I was wondering how the poor apextoollab tool survived the ordeal
3 : To Pick And Place Method You Can Use Tool From Apextoollab , Chinese Tools That Use Dual Sided Tape on a Steel Tool To Remove Platters or Tape Method .
PS : I did a fantastic case today what i worked on for three days And involved much more work then you see in the video .Result success
PostPosted: December 26th, 2019, 10:40
Well,
This Was The Chinese Tool i Was Talking About .The Platter Stand Is #@$@#%$ As WE Cannot Secure it Like We Can To HDDsurgery Stand And Hence When You Like To Rotate Platter It Will Fall Down
PostPosted: December 26th, 2019, 10:49
Luke ,
I will Add Some Details Soon To Your List i Am Working Day And Night On These Damn Platter Cases These Days
PostPosted: December 30th, 2019, 3:38
Amarbir[CDR-Labs] wrote:
Maddin ,
... thanks a lot!
Users browsing this forum: Majestic-12 [Bot] and 88 guests
