Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
 Post subject: Re: PCB Swap Question Seagate SSHD
PostPosted: March 28th, 2019, 14:20
Hi, anybody knows a Seagate terminal command for ST500LM000 to disable NVC function (NAND).Thank You
PostPosted: July 18th, 2019, 16:07
managerharry,
HOW DID YOU USE. terminal mode to get into drive if its dead no power? do you have instructions
PostPosted: February 10th, 2020, 9:02
Hello guys,
I have the same model: ST1000LM014
And there is not sound, no spinning.
Do you think it will work if I change the PCB and swap the rom?
Or should have a complete functiona HDD, made a secure erase using SEATOOLS and than swap the rom and change the PCB.
Thank you in advanced.
Users browsing this forum: No registered users and 47 guests
