 Post subject: Toshiba Hard Drive PCB Swap Replacement G3448A
PostPosted: January 26th, 2020, 12:15
I have to swap PCB for this HDD, with PCB G3448A. I know I have to swap Bios Chip, but I don't know if I have to change both chips shown in the picture attached (https://www.hddzone.com/images/PCB-G3448A.jpg) or just one of them. In that case, which one?
File comment: G3448A
 Post subject: Re: Toshiba Hard Drive PCB Swap Replacement G3448A
PostPosted: January 26th, 2020, 20:04
I forgot to mention that HDD is Toshiba mq01ubd100
PostPosted: January 27th, 2020, 0:03
If you purchase the PCB from hdd-parts.com, they will transfer the firmware at not extra cost. AIUI, you only need to transfer IC602.
PostPosted: January 27th, 2020, 5:44
This is correct. The other one handles the USB bridge.
PostPosted: January 27th, 2020, 9:40
+1
PostPosted: January 27th, 2020, 16:03
Be very careful with the temperature to desolder and weld the ROM. If it breaks you will not be able to recover the data.
PostPosted: January 27th, 2020, 19:53
btw, rom on toshiba can be written using simple tools and some knowledge. However, some tosh family caused me headaches, maybe it was MQ01...
PostPosted: February 11th, 2020, 5:41
What temperature do you recommend, more or less, for this ROM?
Users browsing this forum: No registered users and 46 guests
