 Post subject: Are external hard drives safe from static electricity?
PostPosted: February 24th, 2020, 11:55
I work as a film and television editor adn I keep my own archive of the past projects.
I have around 10 external hard drives from various manufacturers, some 2.5 inch and some 3.5 inch. They are all protected with plastic enclosure (I bought them like that).
When I transport and store them, I use hdd cases like this one (I own several of this one specifically):
https://uk.hama.com/078361/hama-univers ... ze-s-black
Since the inside of the cases is made out of some sort of fabric material: it says 100% polyester, I assume when you put the hdd inside it and rub it a bit, some static electricity is present.
I have never had any problems whatsoever, but I am wondering, whether transporting and storing your external hdd in these type of cases is completely safe?
And the main question: does the plastic enclosure that the hdd comes in completely protect the hdd from this sort of static electricity (generated by a bit of rubbing to the fabric material) or should I be worried and take some extra precautions?
 Post subject: Re: Are external hard drives safe from static electricity?
PostPosted: February 27th, 2020, 3:16
I think you're good. Never heard of static taking out an external hard drive.
