Hello I have received charger 2 days ago with normal calibration then click then continuous spinning then click then continuous spinning with full ID but all sectors shows zero, after temporarily fixing the issue and access user data I decided to fix the issue permanently, so I converted the drive to SATA and fixed SA for permanent access user area. The weird thing is that with SATA PCB shows first 8000000 as UNC and converting back to USB all sectors returned readable without any issue and I could full image the drive.
Is there any explanation?
