 Post subject: wd60purx-64t0zy0 pcb change...
PostPosted: March 5th, 2020, 5:36
Hi !
I have 2 drives of this type , identical. One is with bad PCB - not spin, another in bad condition.Some test say that some heads are going to die.
I put PCB from bed heads drive to not spinning drive and restore full backup from bad heads hdd.
i have wdmarvel license.
After restore drive spinning, visible , initializing in WDmarvel. After that I run full LBA scan, add defects to p-list.Format.Clear SMART.
The drive I working well, but when I put it in sinology - SMART report Is HDD failing.Short smart does not complete.
I certainly miss something important in this process.
Now I am currently filling the disk with files and for now it is working ok, butt like i said short smart test does not pass.
Run DLG - the same - qiuck test on the drive 2 did not complete ! Status code=3 /fatal or unknown error/ Failure chekpoint=99/unknown test/
Run HDDscan - the same.
Some ideas what to do ?
 Post subject: Re: wd60purx-64t0zy0 pcb change...
PostPosted: March 6th, 2020, 3:38
Hello !
Somebody can help with recommendations ?
What i miss or do wrong ?
Thanks !
Users browsing this forum: No registered users and 121 guests
