 Post subject: BSY after clearing NAND
PostPosted: June 3rd, 2020, 12:05
Hi I have ST500LM000 SSHD as donor and trying to prepair it by clearing the NAND by O/I and transferring the patient ROM to the donor pcb.
i get always this immediately after power on and also Stuck on BSY:
   SOC PSM Mode =    0001      Atomic
   SOC PSM Command = 0001      Flash Write
   SOC PSM Status =  0011      Invalid PSM Parm
Clump Parametrics:
                    Clump = 101B
                 DataType = 0000
                 ModeFlag = 02
               EraseCount = 00000000
           EraseFailCount = 00
         ProgramFailCount = 00
            WeakReadCount = 00
    UncorrectableECCError = 00
---SOC PSM Command History---
Cmd#/PsmCmd    Clump     Offset     Length     LbaMid     LbaLow   LbaBits39To32 Options   Status    DestClump  DestOffset
     0001       101B       0000       16C7       0000       0000       0000       C000       0011       C207       0C94
     0901       101B       0000       16C7       0000       0000       0000       C000       0011       C207       0C94
     080A       000C       1720       0020       0000       0000       0000       C200       0024       C207       0C94
     0700       000C       1720       0020       0000       0000       0000       C000       0001       C207       0C94
     0600       000C       1700       0020       0000       0000       0000       C000       0080       C207       0C94
Flash Statistics:
BridgePSMDriverID = 0x0009
FlashID 98D7 8493 72D7
Flash Manufacturer: Toshiba19nm
Flash Capacity = 00008 GB MLC
Combo Mode
NumberOfClumps =    0x0400
LBAsPerCluster =    0x0020
LBAsPerClumpMLC =    0x4000
LBAsPerClumpSLC =    0x2000
ClustersPerClumpMLC =    0x0200
ClustersPerClumpSLC =    0x0100
DefragClumpThresholdInSectors =    0x2000
UserSLCMaxSizeInClumps =           0x0180
NumberOfPotentiallyWrittenClusters =    0x0002
DefectListRevisionKey         0x0002
SLC Clumps                    0x01A7
ActiveClumpInfo
   Active Journal             Clump 000C   Offset 1720
   Active Anchor              Clump 0001   Offset 0000
--- ALF RFS Recorder ---
--- Recorder prints backwards: newest to oldest ---
IARCount    Status       Clump      ClumpSentinel      FunctionOrigin
ALFRecorder:
   End of ALF Recorder Trace
I put the donor pcb and ROM back as it was and also getting the same error :roll:
 Post subject: Re: BSY after clearing NAND
PostPosted: June 4th, 2020, 6:28
I think O/I damaged the NAND on the PCB, because i tried it on another PCB and getting the same error
Users browsing this forum: Majestic-12 [Bot] and 204 guests
