 Post subject: wd20nmvw problem
PostPosted: June 8th, 2020, 8:19
drive become ready under PC3000, but when I try to work with WD utility become busy.
If I block SA access and load LDR from SA in kernel mode I can backup resources.
But when I allow SA access and power off/on same behavier.
I try also to replace heads. Same behavier.
Any advice
 Post subject: Re: wd20nmvw problem
PostPosted: June 8th, 2020, 10:32
Heve you tried fix slow startup in ram, then stop reallocation process and clear relo list?
Stop reallocation by editing ID in ram.
My firmware database:
Users browsing this forum: Google [Bot] and 51 guests
