 Post subject: Compatible ROM for WD10JMVW-11AJGS4
PostPosted: July 17th, 2020, 22:28
Hello every one,
I am looking for a compatible ROM close enough to get access to SA on WD 2.5" USB drive with below specifications:
MDL: WD10JMVW-11AJGS4
DCM: HBKT2BK
DATE: 13 JUL 2016
S/N: WXN1A563DUSA
Product of Malaysia
Your help is greatly appreciated since the original PCB was lost by customer!
Thank You
 Post subject: Re: Compatible ROM for WD10JMVW-11AJGS4
PostPosted: July 18th, 2020, 17:09
kevinafg wrote:
Hello every one,
DCM: HBKT2BK
DATE: 13 JUL 2016
S/N: WXN1A563DUSA
Product of Malaysia
Thank You
Search the HDDSurgery firmware database. Best place to get a very close match.
PostPosted: July 18th, 2020, 18:24
Thanks ddrecovery I've already tried HDDsurgery nothing close enough to work from there. I tried most of ROMs available Online plus 20 of my own but no luck so far and that's way I am wondering if anyone has something very close to this WD portable drive.
PostPosted: July 18th, 2020, 19:07
Is your rom corrupted?
Did you try to get access by uploading ldr file?
What's the micro code of your rom?
My firmware database:
PostPosted: July 19th, 2020, 11:25
I don't have the original PCB and without proper ROM there is no surface access and SPT reading.
PostPosted: July 19th, 2020, 12:09
Without original 4f module in ROM it is very difficult to get access to SA, but possible and expensive. Getting many ROM versions wont help you much.
Angel Data Recovery
PostPosted: July 19th, 2020, 16:38
I did it before, usually same month products have very similar Micro program version.
PostPosted: July 20th, 2020, 4:54
4F is unique in FBLITE family , your issue is not rom but rom module
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: July 20th, 2020, 16:39
I can recover it even if 4F is missing, using whatever rom. ... in case you need it ...
PostPosted: July 20th, 2020, 17:05
Great, Thanks Pepe just let me know what do you need?
PostPosted: July 20th, 2020, 17:13
Which parameter in 4F is the problematic one?
PostPosted: July 21st, 2020, 11:40
For these discs the adaptations of the 4F module are important.
These are in the following positions:
1C0-1C3 HEADER
1C4-1C7 HEAD 00
1C8-1CB HEAD 01
1CC-1CF HEAD 02
1D0-1D3 HEAD 03
1D4-1D7 HEAD 00
1D8-1DB HEAD 01
1DC-1DF HEAD 02
1E0-1E3 HEAD 03
The most important of the 4-byte groups are the last 2.
In this way, if we erase the adapters of heads 1, 2 and 3, the hard disk starts, if we erase 0, 2 and 3, the hard disk starts but takes longer, read the second copy.
The 4F module can be zeroed and you only have to look at the positions:
1C4-1C7 HEAD 00
1C8-1CB HEAD 01
and in particular the last 2 bytes of each position.
I pass an example with 2 roms, one original and another modified, the 2 fully operational for head 0.
ROM.rar [641 Bytes]
Downloaded 459 times
PostPosted: July 21st, 2020, 12:10
1C4-1C7 HEAD 00
1C8-1CB HEAD 01 -> NOT
1C4-1C7 HEAD 00
1D4-1D7 HEAD 00 -> YES
PostPosted: July 21st, 2020, 22:30
Thank you every one especially mhp666 for your detailed explanation but I think trying all the combinations for 1C4-1C7 & 1D4-1D7 for head0 takes quite some time Which out of the range of estimated time for this job.
PostPosted: July 22nd, 2020, 2:46
It takes not more than an hour for me, shipping is the slowest part...
Users browsing this forum: Google [Bot] and 84 guests
