 Post subject: 2060-800041-003 compatible sata pcb
PostPosted: January 11th, 2019, 7:47
Hi guys I have this pcb and I need to connect to mrt I haved try to use MRT WD-USB interface whit E71 - E72 - E73 - E75 pin and i have powered the disk with usb cable but nothing. Exist a SATA PCB compatible to this ? thanks for help and suggestions
 Post subject: Re: 2060-800041-003 compatible sata pcb
PostPosted: January 11th, 2019, 9:36
A friend suggested I remove the capacitors to open the usb bridge if I want to use the adapter with the wires on the sata. Someone knows which capacitors to remove on this pcb, I think mrt does not work with the adapter for this reason. Thank you
PostPosted: January 11th, 2019, 9:40
This is the pcb. This disk have this problem, when powered spin normal no click no noise, windows recognize the disk but no partition and disk immediately spin down.
PostPosted: June 25th, 2019, 10:31
look this post here is what capacitors must be removed. with pictures. :idea:
https://www.alldataback.com/wd-usb-external-hard-drive-change-to-sata-interface/
PostPosted: July 1st, 2019, 8:54
thanks bro
PostPosted: August 12th, 2020, 6:18
jobojobo,
How to find diodes in this board
Users browsing this forum: No registered users and 67 guests
