 Post subject: Synology Shared folder
PostPosted: May 24th, 2020, 8:20
Hi.
Someone can help?
Delete shared folder on synology rs2416+ with 12 HDD and raid5.
Volume stay same only shared folder are delete.
Best regards.
 Post subject: Re: Synology Shared folder
PostPosted: May 24th, 2020, 8:43
There's no easy option here to undelete it. Nothing can be done through the Synology that is for sure, so don't bother trying things through the user interface. You can only make things worse.
If you can't afford to lose this data, my recommendation (since you are in Canada) is to contact Recovery Force in Guelph.
PostPosted: May 24th, 2020, 10:59
+1 Recovery Force
PostPosted: August 18th, 2020, 8:23
kittysoman2013 wrote:
Delete shared folder on synology rs2416+ with 12 HDD and raid5. Volume stay same only shared folder are delete.
There is some chance the data stay on the disks. Did you delete with SMB/NFS or directly with DSM? Did free volume space increased or not? Go to Synology forum first.
Users browsing this forum: Bing [Bot] and 69 guests
