WD palmer Recovery plan
August 26th, 2020, 4:33
By I have to recover data from a WD palmer Family disk ( WD10SDZW -11UMGSD) .
It is not supported in my udma . Disk gets detected and I have selected Venus to enter in utiliy.
I was able to copy MFT .SIze of data is high (600GB). Is there anyway I can do this recovery with my limited resources ?
Which is nearly matching family I should select ?
Re: WD palmer Recovery plan
August 26th, 2020, 9:53
Palmer is supported in UDMA...
August 26th, 2020, 10:28
Nick_CT wrote:Palmer is supported in UDMA...
I believe he means Green card (no more updates)
August 26th, 2020, 10:29
Sorry you're right, I'm confusing it with Express.
August 26th, 2020, 10:30
The one I had to drill a hole through on video :)
August 26th, 2020, 11:12
Nick_CT wrote:The one I had to drill a hole through on video :)
heheheheh and feel bad about it... :lol: :lol:
August 28th, 2020, 3:46
higgsboson wrote: ( WD10SDZW -11UMGSD) .
It looks like a USB drive....Did you change the PCB?
August 28th, 2020, 5:39
Yes it is WD My passport . I did not changed PCB , I mean PCB was not an issue.
August 28th, 2020, 5:40
Hi einsein9
Its not Green , its Red card updated till 2018 , but it is not having palmer family.
August 28th, 2020, 7:35
it does not depend on that. you can use other family util for backing up firmware but you won't be able to do essential fimrware mods and build head map in DE (unless you know how to do these manually).
August 29th, 2020, 3:10
pepe wrote:it does not depend on that. you can use other family util for backing up firmware but you won't be able to do essential fimrware mods and build head map in DE (unless you know how to do these manually).
Yes you are right pepe , only tool is of no use ,skills are equally important.
I have given this job to one of my friend who has updated UDMA express , but he said he can't do "WD slow responding " functions (as it is not supported for this family) .Due to this bad sectors are not efficiently addressed (large data is skipped) and for last 3 days data copying is on.
Like you said skills to perform firmware tasks manually are really important.
