 Post subject: Seagate ST9750420AS BSY
PostPosted: May 5th, 2014, 17:50
Hello.
I have a Seagate Momentus ST9750420AS (HP OEM drive)
FW: 0003HM1
The drive BSY status register is stuck
When the PCB is connected to the drive the terminal returns:
EarlySpinup Enabled
Rst 0x10M
(P) SATA Reset
RAW OFF
PASS
ProcessRWError -Read- at LBA 000B740F Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000B740F!
ProcessRWError -Read- at LBA 000B7454 Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 000B7454!
LED:000000BC FAddr:00006220
... Last line above repeats every 70 seconds or so
When PCB is NOT connected to the drive the terminal returns:
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067 FAddr:00380338
Ctrl-z does not work nor do any of the standard terminal commands that I have tried, even when the PCB is not connected to the drive.
The client states the laptop the drive was in a laptop that was dropped when the drive quit working. The drive sounds like it is spinning up normally - no clicking or any other noises other than the normal spin up of the drive and the heads sound like they read the SA.
Any ideas?
Thanks!
 Post subject: Re: Seagate Momentus ST9750420AS HP data recovery
PostPosted: May 6th, 2014, 12:36
There are definitely defects on the surface, 50/50 that one of the heads can't read properly.
Error the drive stops on can appear due to the defects in the SA.
Should you need an assistance with this job, please feel free to contact me. Considering the info you posted above, I'd say there's a 90% probability that we'll be able to help.
 Post subject: Re: Seagate ST9750420AS BSY
PostPosted: May 7th, 2014, 14:06
Thanks for the info. I've worked on many Seagate drives where the drive was failing (failed head / SA damage, etc.) but I could still talk to the board through the terminal. I agree that computer being dropped is consistent with head / platter damage. Based on not being able to get the terminal un-stuck I was thinking there is a PCB issue in addition to head / platter damage. If that was the case I was going to try to work on the PCB issue 1st, before the heads. Can you please explain why can't I get my Ctrl+z terminal prompt, even when the PCB is not connected to the drive?
Thank you very much for your response!
PostPosted: May 8th, 2014, 8:45
Easy case
Waqas Ali
PostPosted: May 8th, 2014, 11:13
waqas_ali766 wrote:
Easy case ....
I do not think comments like this are of any help to the OP or anyone else. If you know the solution, share it!
Those who know don’t talk. Those who talk don’t know.
PostPosted: September 23rd, 2020, 16:27
I can testify that a room free of pathogenic microorganisms will not be necessary for this case.
Users browsing this forum: Google [Bot] and 82 guests
