 Post subject: Strange RDMT case
PostPosted: October 6th, 2020, 3:10
Drive HGST HDS721050CLA362 cannot init . Copy 01 of RDMT is unreadable. All other modules are OK.
After SON command the drive put 60 in the CL register.
Any idea what the problem is, or how to solve it?
 Post subject: Re: Strange RDMT case
PostPosted: October 6th, 2020, 10:04
Use ARM utility and load resources from file - the good copy 0 ?
Data Recovery Cape Town
PostPosted: October 6th, 2020, 13:27
Command is rejected by the drive.
PostPosted: October 6th, 2020, 13:44
Any strange noises coming from the drive?
Did you try a virtual translator using good PSHT, RDMT from copy 0?
PostPosted: October 6th, 2020, 14:14
No noises.
I'm just using ATA terminal and VSC commands...
PostPosted: October 6th, 2020, 22:25
You Can Prepare PList and Glist From HDD SA To 2 Files ,1 For Plist and 1 For Glist .Once done you can built virtual translator into ram using these two files ,In your case in pc3k it should work like a charm
PostPosted: October 7th, 2020, 4:49
I think I was clear enough in my previous post. I don't have PC3K, MRT, SeDiv, etc...
I don't know VSC for loading files into RAM.... but I'll be grateful if sombody pass it to me.
Users browsing this forum: mecrazzy243 and 79 guests
