 Post subject: How can I merge G-list of an old Samsung HM080JI Drive
PostPosted: May 10th, 2020, 10:35
Hi
I have an old laptop I'd like to use for retro programs.
Hard drive is 2.5" SATA Samsung 80 GB. Model number HM080JI.
It has bad sectors but I'll use it for nothing critical so I'd like to do a surface scan on it and put all slow sectors to P-List.
Which software can I use that's capable of handling Samsung drives?
 Post subject: Re: How can I merge G-list of an old Samsung HM080JI Drive
PostPosted: May 11th, 2020, 3:45
WCube, SHT, SHTR, Samsung HDD Repair Tool, SeDiv, etc.....
PostPosted: May 11th, 2020, 6:05
It is a magma drive so from what I gather SHT demo should be working in full mode for it.
any pointers on how to proceed from there? should I do the burn-in stuff or are there simpler things I can do before?
PostPosted: October 5th, 2020, 10:43
Okay I tried SHT 4.0.9 Demo, SHRT 2.0.0.3 Demo and SRT but neither can merge A-List to S-list.
Is there any other tool for this?
PostPosted: October 6th, 2020, 2:31
If you know how to use WCube, command is fmtu. On Samsung HDD Repair Tool there exist a button for this purpose.
Are you sure you did the right thing?
PostPosted: October 6th, 2020, 2:57
I guess ? :D
In Samsung HDD Repair I can only see Clear smart / Clear A-List etc. buttons. No buttons to merge A-List S-list.
Apart from that I tried Demo versions of SHT 4.0.9, SHRT 2.0.3, HDRT 1.0. Contrary to what it says in the manual, they don't allow writing S-list in the demo version.
I'll see if I can make use of WCube.
PostPosted: October 7th, 2020, 11:22
In fact Clear A-List Merge A-List to S-list.
PostPosted: October 7th, 2020, 17:58
Where did you get it? Mine only shows clear
PostPosted: October 8th, 2020, 1:24
I shouldn't bother answer you.
:roll: :roll: :roll:
PostPosted: October 8th, 2020, 3:38
A list = G list.
If you press clear G, it will put G(A) into S.
Presumably, at least.
PostPosted: October 8th, 2020, 4:06
I'm sorry do you mean the "Clear" button actually does merge?
PostPosted: October 8th, 2020, 16:54
northwind wrote:
A list = G list.
Thanks.
I tried both "Clear G-list" and "Clear G-list 50" buttons. They do what they say, S-List wasn't changed.
PostPosted: October 9th, 2020, 7:37
In such a case you have to run BURNIN test, if you know how....
PostPosted: October 9th, 2020, 18:45
Yeah, I'm scared to do it :| I bricked few WDs in the past while trying to do self-scan so I'd rather not touch it :cry:
Users browsing this forum: Google [Bot] and 75 guests
