 Post subject: Seagate Grenada Is fw responsible for logical corruption
PostPosted: December 1st, 2020, 1:05
Hi Frineds I am working on a hard disk which is attached to a PLC automation device.
Its Seagate OEM HP fw disk (Detected as Grenada in PC3K)--
ST2000DM001-7ER164
FW -- HP 52
Disk has slightly delayed detection , I am unable to access SA by ATA and Terminal.
In DE I have been able to copy MFT's of one partition (100% MFT sector copied) but strangly data folders are empty .
Is there any co relation between FW not getting accesssed and improper logical data ? As per cust. There are 2-3 partitions but in DE GPT only 1 OS partition is accessible.
What should I do now to gain SA /Modules access.
Here are snaps of the disk.
 Post subject: Re: Seagate Grenada Is fw responsible for logical corruption
PostPosted: December 2nd, 2020, 1:21
I am not sure but Rom patching might be needed to unable tech Mode ,experts pls. comment
PostPosted: December 2nd, 2020, 6:12
Update to this case ----
I have patched ROM and terminal is unlocked. I tried to mount disk and run a data recovery software. Strangely now folders aren't empty.
So data is present but due to FW corruption I am not getting this data.
PostPosted: December 8th, 2020, 3:56
This model is SED drive . I think in this case partition shift has occured.
PostPosted: December 11th, 2020, 5:49
This case is still open and I can give remote access to my pc3000 if anyone wants to study.
How to interpret following terminal
(P) SATA Reset
RAW OFF
PASS
6Gb Max Speed lowered to 3Gb for Intel bug
Send Status: COMRESET seen
PowerTransition
(DOS) File Save DONE
PowerTransition
PowerState = IDLE1
HighPowerMode Status 0001 Req 0002
PowerState = IDLE2
HighPowerMode
TCC:001B
Status 0001 Req 0034
TCC:001B
HighPowerMode Status 0001 Req 0034
TCC:001B
TCC:001C
TCC:001C
Users browsing this forum: Google [Bot] and 81 guests
