1 of the 3 HDDs (Western Digitial WD3003FZEX Black 3TB SATA 6GB/S 7200RPM 64MB Cache 3.5IN Hard Drive) fails in a RAID 0 array. At first, it disappears from the OS. Then, it re-appears after re-plug the cables. However, it is not stable, sometime even the serial number cannot be read out (see below).
I try to clone it first with ddrescue, but even cannot even read a byte.
sudo ddrescue -f /dev/sdc Port1.img Port1.log
GNU ddrescue 1.22
ipos: 3000 GB, non-trimmed: 0 B, current rate: 0 B/sB/s
opos: 3000 GB, non-scraped: 0 B, average rate: 0 B/s
non-tried: 0 B, bad-sector: 3000 GB, error rate: 23256 kB/s
rescued: 0 B, bad areas: 1, run time: 14h 18m 13s
pct rescued: 0.00%, read errors:5906318682, remaining time: n/a
time since last successful read: n/a
Finished
sudo ddrescue -f -d /dev/sdc Port1.img Port1.log
GNU ddrescue 1.22
ipos: 38402 MB, non-trimmed: 38408 MB, current rate: 0 B/s
opos: 38402 MB, non-scraped: 0 B, average rate: 0 B/s
non-tried: 2962 GB, bad-sector: 0 B, error rate: 875 MB/s
rescued: 0 B, bad areas: 0, run time: 17s
pct rescued: 0.00%, read errors: 586172, remaining time: n/a
Copying non-tried blocks... Pass 5 (forwards)^C
Interrupted by user
sudo ddrescue -f -d -R /dev/sdc Port1.img Port1.log
GNU ddrescue 1.22
ipos: 2895 GB, non-trimmed: 105045 MB, current rate: 0 B/s
opos: 2895 GB, non-scraped: 0 B, average rate: 0 B/s
non-tried: 2895 GB, bad-sector: 0 B, error rate: 2350 MB/s
rescued: 0 B, bad areas: 0, run time: 46s
pct rescued: 0.00%, read errors: 1602973, remaining time: n/a
Copying non-tried blocks... Pass 5 (backwards)
Here is the HDD information, the one without serial number of the broken one. After reboot, there is a chance to read the serial number successfully, and it is WD-WMC5D0D61CYD.
sudo mdadm --detail-platform
mdadm: imsm capabilities not found for controller: /sys/devices/pci0000:00/0000:00:11.4 (type SATA)
Platform : Intel(R) Rapid Storage Technology
Version : 14.8.0.2377
RAID Levels : raid0 raid1 raid10 raid5
Chunk Sizes : 4k 8k 16k 32k 64k 128k
2TB volumes : supported
2TB disks : supported
Max Disks : 7
Max Volumes : 2 per array, 4 per controller
I/O Controller : /sys/devices/pci0000:00/0000:00:1f.2 (SATA)
Port2 : /dev/sdd (WD-WMC5D0D9X6D8)
Port3 : /dev/sde (WD-WMC1F0EARDW0)
Port1 : /dev/sdc ()
Port0 : - no device attached -
Port4 : - no device attached -
Port5 : - no device attached –
The motherboard is ASUS X99-E USB 3.1, the RAID 0 is setup with Intel RST, and the I/O Controller is still left in RAID mode in BIOS. However, the raid array only consists of WD-WMC5D0D9X6D8 and WD-WMC1F0EARDW0 in BIOS now, the broken is now a non-member drive. The system must somehow detect the drive failure and remove it from the array automatically.
Any further effort I should try before given if I would like to clone the failed drive? Change the PCB? Thank you.
