 Post subject: Replace ROM in Seagate
PostPosted: April 27th, 2005, 21:42
Hy, i need yours experience, I Have a Seagate ST320413A U5 Firmware 3.40 20 GB.. I need to recover data in it , but in the PCB have a circuitshort in a pin from the combo chip (spindle motor/heads actuator) I have found a Donnor PCB Very similar,
in CPU but not similar in NVRAM, my question is there any problem in this case? o does i need to replace from the bad the ROM And NVRAM and put on the Donnor PCB , then to the HDA
Thanks for all help
 Post subject:
PostPosted: April 28th, 2005, 1:21
Replace the combo chip ( SH6950C ) from the donor on your PCB.
 Post subject:
PostPosted: April 28th, 2005, 2:48
If the Flashes are 49F1024 and M29F102BB, they are completely interchangeable. I saw theese two on seagates.
 Post subject: ROM Replaced in Segate
PostPosted: April 28th, 2005, 17:52
now i replace the ROM From the Bad PCB and put in the New PCB but the hard disk its not initializing in S.A ,
Any idea
 Post subject:
PostPosted: April 29th, 2005, 9:28
Does it spin up and move it's head?
What type of flashes were on the boards?
 Post subject:
PostPosted: May 1st, 2005, 11:21
you have a try
replace the bad rom to the normal pcb.
Users browsing this forum: No registered users and 86 guests
