 Post subject: HDDs are unaccessible after secure erase attempt
PostPosted: February 27th, 2021, 5:10
Hi Guys. I had 5 HDDs in RAID5 config on Adaptec 6805 controller. Before giving them to someone I decided to erase them all at once vs one by one and started "ATA Secure Erase" process with Adaptec 6805, without reading the precautions (my bad, as I now understand). Couple of days later I interrupted the process as I was thinking it's taking too long and is too slow so there should be something wrong with it. Turned out the process should NOT be interrupted or drives can be damaged. Plus it does 3 passes and that's why it's so slow. Here:
https://ask.adaptec.com/app/answers/det ... s-and-ssds
Now I can't access 3 out of 5 HDDs. DRS software reports Firmware as "locked" and I can't initialize them or access them. Does anyone knows a way to recover them? Any help or suggestion would be appreciated!
 Post subject: Re: HDDs are unaccessible after secure erase attempt
PostPosted: February 28th, 2021, 6:37
Some additional info I forgot to mention in y original post:
two locked drives are 8TB Seagate Archive HDD, ST8000AS0002
one locked drive is 8TB Seagate Barracuda ST8000DM004
HDPARM report for ST8000AS0002:
Security:
Master password revision code = 65534
supported
enabled
locked
not frozen
not expired: security count
supported: enhanced erase
Security level high
454min for SECURITY ERASE UNIT. 454min for ENHANCED SECURITY ERASE UNIT.
Users browsing this forum: gps31, Majestic-12 [Bot] and 52 guests
