Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD10EZEX-22BN5A0 inaccessible
PostPosted: March 12th, 2021, 15:30
So it was a HPA problem ...
the problem was generated by the wrong capacity actually, the disk actually when started without module 02 disabled it showed the capacity of 1953525169 while the right capacity is 1953525167 but even if I manually inserted it it didn't work. When after writing it I loaded the module 02 with the serial the disk worked and now I'm copying. I don't know why I had to load it with the serial in the past it was enough to load it normally and it worked. Thank you all
Users browsing this forum: Majestic-12 [Bot] and 40 guests
