 Post subject: HDDScan results bad?
PostPosted: June 9th, 2021, 9:21
Good morning, I have a computer that was making a bit of noise on operation so I checked the hddscan results and I don't have bad blocks on the whole drive but I do have a could blocks that are >500ms and 1000's of blocks >150ms. It's also showing temp at 56C and some 71000 running hours. Crystaldisk also shows caution on the drive. I'm not sure if I should toss the drive or continue using it since it is for the os. I'm not sure if the few reallocated sectors, the temperature report, and slow blocks combined is enough to condemn the drive or it I can continue using it with caution.
File comment: Hddscan, crystaldiskinfo, crystaldiskmark, gsmartcontrol
hdd reports.zip [340.24 KiB]
Downloaded 641 times
Users browsing this forum: No registered users and 88 guests
