 Post subject: WD3200AAKB Size error in Bios and windows
PostPosted: October 8th, 2021, 14:26
Hello
My Harddrives shows ion Bios and Windows a size of 17gb it should be 320 i did already tryt many things out to get it corrected, last change would be the firmware
i´m looking for a firmware.bin i can inject with hddhackr.
The Harddrive spec are WDC WD3200AAKB-08U6AA0
Thanks in advance
 Post subject: Re: WD3200AAKB Size error in Bios and windows
PostPosted: October 10th, 2021, 4:02
sorry i did a error in the spec.
it is WDC WD 32 00AAKB-00WHA0
PostPosted: October 11th, 2021, 13:06
Don't replace the firmware modules with foreign ones. Instead you should use to WDMarvel to dump the existing firmware, then modify those modules.
Alternatively ...
HDDHackr - lost UNDO.BIN - how to restore capacity:
http://www.hddoracle.com/viewtopic.php?f=86&t=141
