 Post subject: ST2000LM003 \ HN-M201RAD/AS1 - can't even low level format
PostPosted: October 23rd, 2021, 17:38
A newbie here, have mercy please ))
Hoped to cut some space with BB from this PMR beauty, to get around 1TB good space for media files, but can't even low level format this Seagate (that looks more like a Samsung with 57600 baud rate in terminal)
Would anyone help with decision on that drive and what can be done to make it more alive? No data recovery needed.
Sounds from a drive, possible to listen online without downloading:
https://www.veed.io/download/015c77f0-d4dd-41e6-ae51-0a20b1a4f22d
https://www.veed.io/download/6725b86c-b8d9-4120-96b7-31fa380166ca
Feed from a Terminal:
ActiveFW : 00FWVer : 0001DDR detected:32MB*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002U
S_0
PCBA I/O Voltage : 1.8V
PREAMP : 1.8V
FLASH : 8Mbit
KonaRev: ST 4.2
Kona FSYS divider: 1
VN on
VN off
SO_1
Set SDIS
Set Target RPM = 5409(0000906Fh)
IS Max= 200 (000Eh)
SU Max= 870 (003Fh)
DefaultKval : 751 TargetKval : 2799
RPLDone
RPA.........ActiveFW : 00FWVer : 0001DDR detected:32MB*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002*PAUNI_L2958*PA VID=0011 PN=000E Rev=0002U
S_0
PREAMP : 1.8V
FLASH : 8Mbit
KonaRev: ST 4.2
VN on
VN off
SO_1
Set SDIS
IS Max= 200 (000Eh)
SU Max= 870 (003Fh)
RPLDone
S_0
PREAMP : 1.8V
FLASH : 8Mbit
KonaRev: ST 4.2
VN on
VN off
SO_1
Set SDIS
IS Max= 200 (000Eh)
SU Max= 870 (003Fh)
RPLDone
RPA..............Done
HO..Done @RPM= 643
RU..........................................Done @RPM= 5400
ST..Skip
SUT= 1794
mS1 00000002
VDAC Offs K0 ............Done: 15
VN on
SHK on
VBEMF Offs ....Done
VBEMF Gain ....Done
A1O= - 26 A2O= -  4 SWO= -  4
A1G= 1329 A2G=    7 SWG=   20
Rvcm=  10973 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load  = 3000 mips
LD..OK
DSA on
SK C:  8064 H:0
Loaded FIT ( 0: 0: 1)
CalibTable Loaded. Rev:0x1C
ResoTable Loaded. Rev:0x02
Bump Limit Loaded. Rev:0x01
RRO1xTable Loaded. Rev:0x01
Fw Active 00
Ovly loaded to 0x1005E490
Ovly loaded to 0x00014D00
FdtTable Loaded. Rev:0x02
NLD Load Success
Found ZH Skew
Up MC
PwrOn RRO1x @ H0
Table) cos = 272640, sin = 577280
Coeff) cos = 39681, sin = 25752
DiskSlip : 184 [SrvTrk]
DiskSlip : 193 [SrvTrk]
0. phs diff 2 [wedges] Table) 70, coef) 68
PwrOn RRO1x @ H2
Table) cos = 277248, sin = 571392
Coeff) cos = 17851, sin = 64761
DiskSlip : 183 [SrvTrk]
DiskSlip : 197 [SrvTrk]
4. phs diff 2 [wedges] Table) 69, coef) 71
PwrOn RRO1x @ H4
Table) cos = 277760, sin = 571392
Coeff) cos = -11415, sin = 63100
DiskSlip : 195 [SrvTrk]
4. phs diff 3 [wedges] Table) 69, coef) 72
TgtCyl:     832
Hd:   4 Zn:   0 Avg.:      77
TgtCyl:  316832
Hd:   4 Zn:   1 Avg.:     803
SVCAL(0080,0000)-->PASS
>>Insitu : enabled
DSA mode enabled
ReadyTime = 2796269 us
FLASH protection Enable
LRC: 00000485 code activated
ENG>VN off
DSA off
mS1 00000002
VN on
DSA on
SK C:180844 H:0
[GL][000000000->3A6]
[GL][046607800->756]
SR:0
AP:1 C:  7690->114266 H:3->5 AP Cnt: 0
SK C: 16203 H:5
ExTm4SR: 25
X00:1683E.5.11F|0001 3340 L046607800 R:3340 p0001 s011F l0000 0000/0001
DFF___
FSA___
id:0, st:1_itic,147,238,-100
id:0, st:1_itic,115,264,100
AP:1 C:114265->114267 H:5->5 AP Cnt: 0
UF 3 1stGrayErr Hd:5
Fault Status : 4000 0000
SK C:116529 H:0
S_2 00000101 000000FD 00000101 00000000SR:0
AP:1 C:116529->114266 H:5->5 AP Cnt: 0
SK C:120233 H:0
SR:1
AP:1 C:120233->114266 H:5->5 AP Cnt: 0
SK C:118664 H:0
SR:2
AP:1 C:118664->114266 H:5->5 AP Cnt: 0
SK C:117912 H:0
SR:3
AP:1 C:117912->114266 H:5->5 AP Cnt: 0
DSA off
UD..OK : 20 611
VN off
SHK off
PK_1   C:    76 H:5
VN on
SHK on
VBEMF Offs ....Done
VBEMF Gain ....Done
A1O= - 26 A2O= -  4 SWO=    8
A1G= 1332 A2G=    7 SWG=    8
Rvcm=  10993 mOhm
TgtCyl= 5810
Ulatch= 2000 mips
Load  = 3000 mips
LD..OK
DSA on
SK C: 29500 H:5
ExTm4SR: 630
X0F:1683E.5.11F|0001 3340 L046607800 r:3340 p0000 s011F l0000 0000/0001
ReSync___
DFF___
FSA___
id:0, st:1_itic,209,238,-100
id:0, st:1_itic,93,205,100DAM
DFF___
FSA___
Then it continues pretty much the same with DFF____
Pics of a drive and closeups of PCB, external hosting:
That most right pin in lower row looks really darker than others, but it's very fragile and tiny, dont even know how to clean it.
 Post subject: Re: ST2000LM003 \ HN-M201RAD/AS1 - can't even low level form
PostPosted: October 26th, 2021, 4:44
It complains about top surface and by the sound of it, it doesn't appear to be very happy with its media condition.
I suggest you bin the drive and buy a new one, it's not worth the fuss.
PostPosted: October 26th, 2021, 7:16
Thank You for response! These 2.5" 2TB non-SMR drives are pretty rare now, so I decided (unsuccessfully tho) to reanimate some space from it. Do you think it is reasonable and possible to turn off certain head(s) to cope with this "sounds"? I heard that Samsung HDD Repair Tool can do it.
PostPosted: October 27th, 2021, 5:23
I don't know, I'm sorry, I don't have the tool you've mentioned. Maybe someone else can advise you.
True, you have to go back to 2016 models to find a 2.5" which is CMR :(
However, to be honest I think you're wasting your time. Your drive is obviously degraded and I doubt any tool could resurrect it without hardware intervention.
Good luck though!
PostPosted: October 27th, 2021, 9:49
Northwind,
I meant this tool:
I thought it is not a rarity now ) Though, I might be wrong.
PostPosted: October 27th, 2021, 10:22
Just trying to dig deeper for a "sportive interest", no commercial interest at all )
Users browsing this forum: Google [Bot] and 135 guests
