 Post subject: Advise for WD3200AAJS
PostPosted: December 2nd, 2021, 11:02
Hi all,
In my previous post I got some useful advise to recover a Seagate drive using a donor pcb and a friend who works at a company with colleagues with amazing hotgun skills.
Now I got a new challenge with a WD 3200AAJS. Disk spins and clicks, slows down, starts over, clicks. This cycles about 4 times and then stops.
Drive info:
WD3200AAJS-00B4A0
24 6 2008
pcb part: 2061-701537-G00 AE / 2060-701537-003 rev a
I got a potential donor that is a bit newer
WD320AAJS-60M0A0
8 11 2009
dcm harnht2cgn
pcb part 2061-701590-Y02 AD / 2060-701590-001 rev a
- Is this donor pcb compatible
- Is swapping pcb an option considered the problems with the disc?
thanks in advance!
 Post subject: Re: Advise for WD3200AAJS
PostPosted: December 2nd, 2021, 23:49
Clicking behavior on that drive is an indication of mechanical failure of the reading heads mechanism. PCB on those is usually good. So, swapping PCB won't solve anything.
PostPosted: December 3rd, 2021, 4:38
+1, the described behavior points to damaged heads. I'd stop powering it up and down if I were you, assuming data is important.
PostPosted: December 3rd, 2021, 6:28
Thanks for the advise.
So, up to a recoverylab? As I don't have a cleanroom available.
Any suggestions for a good and affordable lab in the Netherlands? I've used Stellar before but I'm not sure if it is pricing is on a normal level.
PostPosted: December 3rd, 2021, 7:01
https://forum.hddguru.com/memberlist.ph ... ile&u=5963
Marc is in Belgium, may be close enough.
or i can help with it too albeit a bit further off from netherlands...
Users browsing this forum: No registered users and 120 guests
