 Post subject: HGST HTS721010A9E630 Does not read user data from head 0
PostPosted: January 4th, 2022, 5:04
I have a HGST HTS721010A9E630 It does not read a single sector of user data from head 0, but it synchronizes perfectly and is able to read the 2 copies of the SA without problems. It is ready immediately and does not make any strange noise.
Any ideas? Thank you.
 Post subject: Re: HGST HTS721010A9E630 Does not read user data from head 0
PostPosted: January 5th, 2022, 12:00
most probably a weak head...
PostPosted: January 5th, 2022, 12:31
Or it's loosing translator.
odzyskiwanie danych
PostPosted: January 5th, 2022, 13:20
not, if other heads read fine, which i find implied in the OP.
PostPosted: January 5th, 2022, 13:53
Thanks for the info.
I'm going to change plate and heads and I will comment on the result.
PostPosted: January 6th, 2022, 10:21
I would start with imaging with the working head/s first then do a head swap.
Why would you go for a platters swap?
Users browsing this forum: Google [Bot] and 230 guests
