July 11th, 2017, 13:39
Hello
The drive in topic spinning normally and shows (busy).
Terminal output:
EarlySpinup Enabled
Rst 0x10M
ASCII Diag mode
F3 T>
LED:00000067 FAddr:003851A2
Any thoughts?
Thanks in advance.
July 11th, 2017, 19:59
I don't think it helps but ...
- Code:
0x67 UNDEFINED_INSTRUCTION -- Undefined opcode exception
The error would suggest that the firmware has become "lost".
July 11th, 2017, 22:30
Could be dead heads
July 12th, 2017, 5:17
Both fzabkar and Doomer answers are correct and could be simultaneously. I would like to check heads first in order to localize the problem.
July 12th, 2017, 5:23
Thanks for reply fzabkar, Doomer and Martin.
Heads are perfectly working on a donor drive.
I would like to know the read channel points. I will post the PCB pic.
Thanks in advance.
July 12th, 2017, 6:11
With PCB isolated:
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067 FAddr:00380340
- Attachments
July 12th, 2017, 6:47
Here it is.
- Attachments
July 12th, 2017, 6:50
Thank you Martin.
With Donor PCB and donor ROM the drive become ready and reach F3.
Is that mean patient ROM corrupted?
July 12th, 2017, 7:28
Here's the backup of the two ROMs (Patient and Donor):
- Attachments
- Patient.rar
- (435.97 KiB) Downloaded 704 times
- Donor.rar
- (427.3 KiB) Downloaded 664 times
July 12th, 2017, 7:58
It means there is a coruption in SA. Probably, overlay.
July 12th, 2017, 15:06
Does the S/N in the ROM match the S/N on the drive?
July 12th, 2017, 15:46
lcoughey wrote:Does the S/N in the ROM match the S/N on the drive?
Yes.
February 15th, 2022, 8:25
Could you inform the patient and donor PCB number
Compatible PCBs for this model are 100620560 REV.A 100619769 100610953
if you have these PCBs in good condition in your labs, you could see which terminal output to the PCB connecting the HDD and separate from the HDD if F3 T> stable without restarting and crashing
or
EarlySpinup Enabled
Rst 0x10M
ExecuteSpinRequest
LED:00000067
